Best Tool For Tightening Compression Fitting - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-06-2010, 11:32 AM   #1
HomeOwner
Rewards Points: 81
Send a message via Yahoo to Firehawk734
Best tool for tightening compression fitting
I was changing my faucet and of course, where the drain pipe (1 1/2 inch i think) enters into the wall, that compression fitting there loosened a little bit, and there's a slow leak. I have a pipe wrench but the area is too tight to use it. Also, the cabinet has a backing which makes it even more difficult to get a pipe wrench in there.
Is there a good tool for tightening/untightening those fittings? And, where can I get it? Hopefully home depot.
I'm stuck right now, so I would appreciate the help. Everyone else in this house is tired of hearing me drop F bombs every 30 seconds.
Thanks.
NOTHING IS EVER EASY! EVER
Firehawk734 is offline   Reply With Quote
Old 11-06-2010, 12:23 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 830
A pair of "channel lock " adjustable pliers will be your best bet. You may have to inlarge the hole around the pipe a little too.
Review: Harbor Freight Oscillating Tool Tedstor Tools 0 07-13-2010 02:24 AM
Need Help with re-design ttwiss Remodeling 21 05-08-2010 10:27 PM
Compression fitting question JeffWireman Plumbing 9 03-07-2010 08:46 PM
compression fitting Barry J Plumbing 3 11-21-2008 11:19 AM
Installing a Compression Fitting squid226 Plumbing 3 10-10-2008 12:20 AM
