Best Tool / Method For Cutting Pvc Straight - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-02-2012, 01:38 AM   #1
Rewards Points: 562
best tool / method for cutting pvc straight
just wondered if there is an easy goof proof way of cutting PVC pipe first time every time straight and square. Especialy 3 and 4 inch pipe. I have been using a cordless trim saw and rotating pipe. sometimes I hit close, sometimes not so much. trim it straight and invariably short. Better tool??? Better method????
4just1don is offline   Reply With Quote
Old 04-02-2012, 06:17 AM   #2
DIY staff
Rewards Points: 7,174
12" chop saw works well for me.
Alan (04-02-2012)
Old 04-02-2012, 08:55 AM   #3
Rewards Points: 104
Yup; or, if just a few cuts, I sometimes grab a miter box and back saw.
Old 04-02-2012, 09:33 AM   #4
Rewards Points: 3,130
For the smaller sizes, a tubing cutter like is used for copper pipe works fine.
Old 04-02-2012, 09:46 AM   #5
Rewards Points: 338
Tubing cutter works, the easiest method is to buy special PVC pipe cutters that kinda look like large scissors. They come in different sizes and cut PVC like butter.
NitroNate is offline   Reply With Quote
Old 04-04-2012, 03:12 AM   #6
Homerepairguy's Avatar
Rewards Points: 998
Absolutely +1 on the scissors like PVC pipe cutter. Fast, ninety degree clean cuts with no particles or dust like sawing produces. Especially essential if installing a water sprinkler or drip irrigation system where particles are bad.
*** Opps, just noticed that you mentioned 3 and 4 inch pipe. Scratch my post above as I was thinking of cutting 3/4 inch pipe. No experience in using scissors like cutter on large pipes. ***
HRG
Homerepairguy is offline   Reply With Quote
Old 04-04-2012, 12:36 PM   #7
Plumber
TheEplumber's Avatar
Rewards Points: 664
Practice makes perfect-
I use a sawzall a lot on larger pipe. tubing cutters on smaller pipe.
I carry a small pipe reamer that works on all types of pipe. Makes quick clean up on burrs.
Old 04-04-2012, 01:56 PM   #8
MarginallyQualified
Rewards Points: 2,464
Get some "demo" blades.
They're stiffer than regular blades and be sure they are at least 3" longer than the pipe.
Old 04-04-2012, 06:48 PM   #9
biggles's Avatar
build yourself a miter box to fit the pipe then just a hack saw does the trick.or drill a hole in the mark to take the jig blade then just go around the pipe...
Power tool invention TimsTools Tools 13 05-27-2011 09:37 PM
Which tool MattE Tools 12 03-16-2011 09:09 AM
Favorite Painting Tool Gymschu Painting 14 02-24-2011 02:01 PM
I won't burn this luxury tool, right? KUIPORNG Remodeling 15 03-09-2007 03:11 PM
Is this Cutout Tool OK? ADKstorm Tools 3 01-24-2007 12:08 PM
