Best Sump Pump Location - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-20-2013, 08:23 AM   #1
I'm finishing my basement and I'm trying to get a sump pump in before spring. The house was built in the early 50's and has no existing sump pit. The grade around my house slopes from high in front to low in back, the finished part of the basement is the left side, unfinished on the right.
Does it matter where I put my sump pump? Is locating it towards the front of the house, towards the higher graded part, more beneficial or will it keep the water table down all the same? The easiest place to install it would be towards the back of my house but my fear is that it won't be as effective.
Any wisdom appreciated!
bhollon27 is offline   Reply With Quote
Old 02-20-2013, 09:17 AM   #2
MarginallyQualified
Rewards Points: 2,464
Originally Posted by bhollon27 View Post
The grade around my house...
Are you installing perforated drain pipe leading to the sump?
Or is the plan to just dig a hole and set a pump in it?
Old 02-20-2013, 09:36 AM   #3
Just plan on digging a hole and setting the pump.
Old 02-20-2013, 10:10 AM   #4
Roofmaster
Rewards Points: 2,172
Lowest point. Water runs down. Is there a clean stone bed under your slab and around your footings?
Old 02-20-2013, 10:18 AM   #5
I'm not sure if what's under the slab, haven't dug the hole yet. So the logic would be to put it toward the back of the basement?
I guess I thought in the front of the house the grade slopes towards the house (the road is higher than my porch), in the back it slopes away from the house (the back property line is below my deck). So by placing it in the front I would catch the water earlier...? That is faulty logic?
The basement is generally level as far as I can tell, I haven't looked into the grading in my basement to heavily though yet.
Old 02-20-2013, 11:28 AM   #6
MarginallyQualified
I'm not sure if what's under the slab...
Lets go back a few steps.
1) Do you currently have a water penetration issue?
If you do... how long has that been the case?
Is there any pattern to when/where the water shows up?
Old 02-20-2013, 11:34 AM   #7
No water problems, lived in the house for 2 years, several decent rainstorms and no water. Site drainage was already installed when we moved in and works pretty well during a rainstorm.
Just nervous, now that the basement will be finished I am assuming Murphy's Law...
Old 02-20-2013, 12:32 PM   #8
MarginallyQualified
If it ain't broke...
Focus on the exterior work(grading, downspout leaders, etc) and you should continue to be fine.
Tags
basement , finish , grade , location , sump pump
Exterior grade sump pump Jeeper1970 Plumbing 11 12-02-2016 11:17 AM
Backup sump pump & check valve issues Richo Plumbing 8 04-30-2015 11:42 PM
On my way to create the ultimate Sump Pump system... need your input :) Discovery Plumbing 5 06-10-2012 08:37 PM
Sump pump jerks when it turns on Sparkastic Plumbing 3 08-25-2011 07:51 PM
Sump pump float height dac122 Plumbing 8 12-08-2010 09:47 AM
