Best Shower Valve? - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-14-2012, 01:42 AM   #1
JOATMON
ddawg16's Avatar
Rewards Points: 1,122
Best Shower Valve?
What shower valve do you guys suggest as being the best bang for the buck?
My issue...it has to go into a wall that will not have easy access....hence, I don't want to have to worry about it for many years.
Old 08-14-2012, 06:01 AM   #2
DIY staff
Rewards Points: 7,174
Moen and Delta get my vote
Old 08-14-2012, 10:08 AM   #3
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Delta's new universal body gives you the most options after the walls are covered.
I still like moen a lot however.
Journeyman Plumber
Old 08-14-2012, 10:31 AM   #4
JOATMON
ddawg16's Avatar
There is a Moen (or is it Delta) factory near one of the copanies that we deal with....Kinston NC.....looks like I'll be going there in a few weeks for a quicky....I might stop in and see if they have visitor specials....actually, I wouldn't mind getting a tour of the manf facility...
Next question......does anyone make a valve assembly that does NOT go in the wall? As in, 3 pipes coming up out of pony wall to a box with the handle on it?
Old 08-14-2012, 10:34 AM   #5
Doing it myself
Alan's Avatar
Something like that (if you can find it) is going to be exotic and expensive...
the closest thing I can think of is a clawfoot tub valve, but those supplies generally come out of the floor. Not a good situation in a shower....
Journeyman Plumber
Old 08-14-2012, 10:40 AM   #6
JOATMON
ddawg16's Avatar
Just thinking out loud......
Old 08-14-2012, 12:20 PM   #7
x2 on Delta. They seem to be the (near) consensus pick on Terry Love's professional plumber's forum too.
There are plenty of external shower valves. They are common in outdoor showers:
Of course there are fancy expensive ones too:
jbs11 is offline   Reply With Quote
Old 08-14-2012, 12:59 PM   #8
Rewards Points: 52
Moen would be my first choice. Even where heavy mineral deposits are present, the cartridges have always popped out easily for me, replace that, and it's running again. As others have said though, Delta is a good choice as well. Other than those two, I wouldn't look any farther.
The Following User Says Thank You to DexterII For This Useful Post:
oh'mike (08-15-2012)
Need help: Broken stem in Moen shower faucet valve cartridge Learning Lots Plumbing 14 04-06-2015 06:27 PM
Shower Control Valve AZSun Plumbing 1 07-31-2011 12:39 PM
shower valve weirdness wombosi Plumbing 2 06-26-2010 03:59 PM
Shower valve problem stephanieb_1001 Plumbing 1 06-24-2009 05:37 PM
Best 1/2 inch water shut off valve. Nestor_Kelebay Plumbing 10 07-25-2008 12:16 PM
