Old 08-02-2012, 01:54 PM   #1
JOATMON
ddawg16's Avatar
Best Shower Drain?
I'm getting close to starting the shower pan on my two showers....
No, I will not be using pre-fab pans. Both showers are anything but 'standard'...nothing will fit...hence, both will be motar based pans....still tossing around the decision to use hot mop or membrain...
So....which drain should I use? I don't want to break the bank...but I also don't want to do this again in 15 years....
Any other suggestions are also welcome.
Common Sense is like Deodorant. Those that need it the most don't use it.
My
and
Old 08-02-2012, 02:13 PM   #2
Super Moderator
Best Shower Drain?
You need to decide what you are going to do before you choose a drain---
I don't know what is used for Hot Mop----so ask a local plumber or a California member---
For a hand packed shower base with a PVC liner--you need a clamping type drain --covers come in round or square----cost about $35 with a square drain cover---much less with the round---
If you are using Ditra you need a Schluter drain---over $100---
If you are using Hydroban by Latacrete--you could use a Schluter drain or the new drain from Latacrete---never saw a price on one yet--new product---
Here is a link on a lined shower---How to build a shower - Building a shower pan with pre-sloped mortar
bed, liner and curb.
oh'mike is online now   Reply With Quote
ddawg16 (08-02-2012)
Connecting shower drain to toilet drain Liv Plumbing 10 04-17-2013 11:53 PM
Drain pipe size for roll in shower frickell Plumbing 1 04-05-2012 09:36 PM
Very Strange Shower Drain Problem MattWhite Plumbing 12 05-21-2011 12:53 PM
Problem with shower pan and drain ohiogirl1965 Plumbing 1 06-07-2010 07:33 AM
Installing stand-up shower in finished basement without existing drain notenoughtime Plumbing 3 05-16-2009 12:59 PM
