Old 04-07-2012, 11:28 AM   #1
Best Septic Pipe
We are setting up our setting up our new house soon, and am planning the septic system.
What drain pipe is best to the tank and for the leach? 4in of course, but I was looking into the Foamcore Sched 40 PVC as it is much cheaper than the solid pvc, but was worried about the strength.
no_Wedge is offline   Reply With Quote
Old 04-07-2012, 12:00 PM   #2
Civil Engineer
Best Septic Pipe
You did not say where you live. Local code is going to dictate exactly what type of pipe you are allowed to use. Check with your local septic inspector before you install, it is such a PITA to have to remove unapproved pipe when they come to see the system.
Old 04-07-2012, 12:07 PM   #3
Best Septic Pipe
Are you sure there even going to let you design your own system?
I know in my area I'd be facing a big fine even if I did a repair without jumping through some hoops.
I would never use anything less then Sch. 40 PVC, Sch. 80 if it's going to be driven over.
PVC is so cheap there's little since trying to cheap out.
Old 04-07-2012, 03:12 PM   #4
retired elect/hvac/plumb
plummen's Avatar
Best Septic Pipe
Yeah see what the city/cty will allow in your area,I actually had to get a master septic installers license through the dept enviromental quality even with a master plumbers license(big rip off!)
Anyway you might even be able to use sdr26 or 35 just depends on your area.
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is online now   Reply With Quote
Old 04-07-2012, 06:34 PM   #5
Best Septic Pipe
I guess I didn't realize that a lot of places use septics in the city, not near here though lol.
Anyway there is really no code since this is out on a ranch in texas and more than enough acres to allow me to do it myself, so anything goes.
Old 04-07-2012, 09:42 PM   #6
Best Septic Pipe
I live 20 miles from anything even close to a city.
2" pipe on above sink in wall rusted out in a spot bryanp22 Plumbing 9 02-23-2012 09:29 PM
Lead Drain Pipe Project Turbo98 Plumbing 33 01-30-2011 12:27 PM
Water leaking into septic pipe below toilet Gramps Plumbing 1 09-14-2008 10:54 PM
water leak around septic pipe gvanhoven Plumbing 2 04-13-2008 11:29 PM
