#16 | |
Best PSI for full house plus tenantsQuote:
It's possible the service coming from the watermain is galvanized or lead. If that's the case it could be the size of a pencil inside. |
#17 | |
call me E
I also ran a quick, off the cuff water pipe sizing- @ 46-60 psi range, the service will be best if upgraded to 1" with 1" building supply. Again, this was a quick guess based on the fixture count in OP's opening post
When posting in forums, letting us know your location will help others give better feedback/advice/solutions to your questions |
#18 |
Well I unclogged or replaced the fixtures in my home and now I get outstanding pressure from all fixtures even when they're all running at the same time. I guess the problematic fixtures made the pressure appear much worse than it actually was. Having washer on in the basement does decrease the pressure on the main floor fixtures but not significantly.
The pressure does get dramatically worse again on any of the main floor fixtures when the utility sink is on. I assume that's because the utility sink is at the bottom of the water system and releases so much pressure plus it doesn't have a reducing method like the kitchen and bathroom fixtures. I guess this is to be expected. Looks like 49 PSI may be good enough after all. Just barely I bet. |
| Display Modes | |
| My house's previous owner - DIY horror stories | Leah Frances | General Discussion | 118 | 03-14-2013 02:27 AM |
| Attach ledger to vinyl sided house | JamyTheBuilder | Building & Construction | 3 | 03-14-2012 03:54 PM |
| Mast and weatherhead pulled from house, conflicting information from POCO subcontract | SleepnZJ | Electrical | 1 | 11-02-2011 10:39 PM |
| Fixing weekend house staining that went awry | jb888s | Painting | 10 | 08-17-2009 11:01 PM |
| I have Central Heating & Air, but house won't cool down..HELP!! | exiledone1 | HVAC | 13 | 07-10-2009 11:09 PM |
