Old 09-17-2012, 09:42 PM   #1
best placement for shower drain
Below Is a top view of my shower layout.
I am tiling the floor with a pebble tile so I can easily place the drain anywhere.
Where should I place my drain or does it really matter? the X shows where I am thinking of placing it.
The entry way is a walk in entrance with a curb.
hellonoko is offline   Reply With Quote
Old 09-17-2012, 10:11 PM   #2
your tile at the far end will be at least an inch to 1-1/2 above the drain at the entry and the tile at the end close to the drain will be 1/4-3/4 inch above the drain. by putting the drain in the center you can make the outer perimeter level and the slope of the floor more uniform towards the drain.
The Following 2 Users Say Thank You to DannyT For This Useful Post:
jaydevries (09-17-2012), oh'mike (09-18-2012)
Old 09-17-2012, 10:17 PM   #3
in center is the best to get even slope or a trough drain is easier and would look good under the bench. just my 2 cents
be careful my advice only comes from general knowledge i know about the 4 rules it takes to plumb and they are
1 poop needs to flow down hill. 2 hot on left cold on right
3 i get a pay check on Mondays 4 do not chew finger nails at or after work.
jaydevries is offline   Reply With Quote
Old 09-17-2012, 10:30 PM   #4
Doing it myself
Alan's Avatar
I tend to center them over the showerhead or valve more frequently, as customers prefer the way it looks.
Easier tiling to be centered in the shower, although the pre-slope is still set at 1/4" per foot in all directions no matter where you put the drain.
P.S. I haven't heard good things from most of the people who put those pebble floors in.
Journeyman Plumber
Old 09-17-2012, 11:29 PM   #5
Thanks all.
@Alan - What did they say was wrong with them? I was told by a couple people they where really nice, easy to install, looked good, and so on.
Old 09-17-2012, 11:30 PM   #6
personally i would prefer not to stand on the drain when i take a shower. i have seen a few which had the drain towards the end opposite the shower head whether by accident or design. when i redo our master im looking at using a trough drain. you still have to pitch the floor but only in one direction. it will be in the middle but the shower heads will be on either side.
The Following User Says Thank You to DannyT For This Useful Post:
Pirulo (09-18-2012)
Old 09-17-2012, 11:39 PM   #7
@DannyT - That is a good point. Looks like there are some really neat options for those available:
Old 09-18-2012, 09:56 AM   #8
Doing it myself
Alan's Avatar
Originally Posted by hellonoko View Post
Thanks all.
I've heard from multiple people after the fact that they SUCK to clean, and they hurt your feet.
To each their own, though.
Journeyman Plumber
Old 09-18-2012, 01:29 PM   #9
@Alan - Did they say why they are bad to clean? Hard to take apart? Clog often?
As far as stepping on them seems like usually they are put at the door or next to a wall out of the way, did they say they pinch or have sharp edges or something?
Old 09-18-2012, 01:58 PM   #10
i think he was talking about the pebble tile
Old 09-18-2012, 07:41 PM   #11
I know a couple who re-did their bathroom floor with those pebbles.
They are into minimalist and zen design stuff and thought it would look very nice.
They said the floor started to *not* look so nice when they had to get on their hands and knees to (vigorously) scrub the entire floor with "wax on, wax off" motion.
allthumbsdiy is offline   Reply With Quote
Old 09-18-2012, 08:32 PM   #12
Super Moderator
They don't drain well due to the random size and large grout area---causing soap scum to build up quickly.
Old 09-18-2012, 10:18 PM   #13
i know some one who did it and they love it. i think they did it like an exposed aggregate slab then grouted it to get is smoother then sealed it. you could also look into permeable tile or pavers
http://www.wausautile.com/paving/pro...g=53&prod=1106
Old 09-18-2012, 10:45 PM   #14
we center the drain in the center of the overall shower....
The Following User Says Thank You to ben's plumbing For This Useful Post:
oh'mike (09-19-2012)
Connecting shower drain to toilet drain Liv Plumbing 10 04-17-2013 11:53 PM
setting a shower drain Jackets Plumbing 16 05-10-2012 09:48 PM
Avoiding a frozen paver drain BrandonC_1972 Plumbing 2 04-28-2012 10:11 AM
Slow and clogged shower drain help COBRA90GT Plumbing 9 12-22-2009 03:25 AM
relocating washer drain idodishez Plumbing 7 04-21-2009 09:36 PM
