Best Material To Use On Sink Drain - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-29-2010, 08:00 AM   #1
Best material to use on sink drain
I installed a new stone countertop with a built in sink. The instructions said not to use plumbers putty on the drain so I used clear silicone. After 4 weeks it looks like the silicone is giving out and now I am having a small leak. What is the material of choice to use to seal the drain inside of the sink?
RobertN is offline   Reply With Quote
Old 12-29-2010, 08:03 AM   #2
was it 100% silicone or tub and shower caulk? i get leaks sometimes with dap but not with the good stuff
the_man is offline   Reply With Quote
Old 12-29-2010, 09:19 AM   #3
100% silicone is the best. The reason for not using Plumbers Putty is due to it containing oil, which could leech into the main part of the sink. Same thing with marble.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 12-29-2010, 12:27 PM   #4
Plumb or Die!
Generally, all I ever use on a KS is the thin rubber gasket that goes between the strainer and the inside of the sink.
plumber666 is offline   Reply With Quote
Old 12-29-2010, 08:01 PM   #5
isn't that gasket and the paper one supposed to go under the sink?
Old 12-30-2010, 07:35 AM   #6
Thanks for the advice. I picked up some 100% silicone and will give it a try this weekend.
Roebrt
Old 12-30-2010, 07:53 AM   #7
Household Handyman
Rewards Points: 1,408
Oddly enough: I've seen sinks with the thin rubber gasket between the strainer and the sink, with the paper gasket on the bottom. They seem to be working though. If they are not leaking when I'm working on, say the drain, I leave well enough alone. I actually just learned something: Not to use plumbers putty (my favorite) on marble or granite because of the oils leaching. Never noticed it though. Thanks, David
Help: Kitchen sink drain is clogged with grease cips Plumbing 5 03-16-2014 10:43 PM
Pedestal Sink Drain Meridius Plumbing 9 11-11-2010 12:19 PM
Replacing sink drain tube n0c7 Plumbing 7 04-16-2009 07:16 AM
Sink doesn't drain into Septic but somewhere else? 40s house? Where? twilightcall Plumbing 11 01-18-2008 08:36 AM
Drain for an "Outdoor Kitchen" Sink Rich Plumbing 5 08-26-2006 06:48 AM
