-   -   best/correct way to connect a anti frost bib to ProPex (http://www.diychatroom.com/f7/best-correct-way-connect-anti-frost-bib-propex-152865/)
hellonoko 08-06-2012 07:48 PM
1. What is the best/correct method for connecting my anti frost hose bib to ProPex Upinor(Wirsbo) Expansion piping. A brass female connector like this?
http://www.pexsupply.com/Wirsbo-Upon...-PEX-x-1-2-NPT
2. Are there direct to ProPex antifrost bibs?
3. What is the best way to mount this hose bib to cinderblock? My plumber suggested a 2x8 or similar chunk of wood mounted to the cinderblock with tap-cons and then the hose bib mounted to the wood. I would use cedar/redwood or similar, or perhaps a steel plate?
Existing hose bib was cemented in place through the cinderblock and not screwed in.
Daniel Holzman 08-06-2012 08:11 PM
I have the same tubing in my house. I attached a 12 inch long copper pipe to the propex inside the house using a pex/copper fitting, and used a copper frost free hose bib. I like the idea of a wooden board attachment point for the hosebib, either PT or rot resistant wood is necessary
joecaption 08-06-2012 08:47 PM
That fitting will work if you have a 1/2 MPT hose bib.
I like to also add a shut off valve so if the hose bib fails I do not have to shut the whole house down to fix it.
If the hose is left on and it freezes the valve can fail, happens all the time.
I use a lot of vinyl lumber for trim so I use 1 X 6 vinyl and rout an ogee of just cut a slight angle around the outside edges to mount the valve.
ben's plumbing 08-06-2012 09:35 PM
yep male pipe to female connector....wirsbo adapter...:yes:
TheEplumber 08-06-2012 09:59 PM
199 Attachment(s)
It's also nice to anchor the hose bib inside a wall or crawl space as well- especially when using pex
hellonoko 08-06-2012 11:15 PM
Thanks for all the answers.
@joecaption - on the inside the hose bib goes into joist space between a daylight basement and the upper floor. I can see the benefit of putting in a shut off valve but my plumber said you dont want one in your living space. Worth it to make a framed in box for it and a cover panel?
@Daniel Holzman - did you go hose bib -> copper pipe -> pex or was the hose bib just copper itself? Are you saying you went an extra 12" past the hose bib male end into the house? If so why?
@TheEplumber - This makes sense how do you anchor it internally? Mine will be coming in through 1 or 2 joists before it meets the pex.
Thanks!
ian
