Bending Pex Through Floor - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-11-2012, 01:11 PM   #1
Rewards Points: 280
Question to those whose install Pex frequently.
Do you bend Pex or do you use fittings to make 90 degree transitions?
I have to install Pex from a crawlspace up into the house. Either method will work for me. Just would like to know if its best to use fittings instead of placing the Pex under stress by bending it. I know there are products which support the Pex when making 90 degree turns.
Earnie is offline   Reply With Quote
Old 01-11-2012, 01:38 PM   #2
Civil Engineer
Rewards Points: 4,762
There are limits to how much you can bend PEX without causing damage, you may be able to find the minimum radius on the manufacturer's website. When I did my house in PEX (1/2 inch and 3/4 inch), I did a fair amount of bending, all by hand, and the minimum radius for 1/2 inch was about 2 feet. You can certainly use a 90 degree fitting, it introduces a small amount of pressure loss, and of course it costs more money than simply bending the PEX.
Old 01-11-2012, 02:23 PM   #3
Rewards Points: 338
also, there are special bend supports that you can use, check this video:
NitroNate is offline   Reply With Quote
The Following User Says Thank You to NitroNate For This Useful Post:
<*(((>< (01-11-2012)
Old 01-11-2012, 03:23 PM   #4
Love for Construction
<*(((><'s Avatar
Bend where you can using the bending supports. A great advantage to pex over copper is that there are less joints, I wouldn't add any unnecessarily if you can help it. Adding a 90* joint will introduce 2 additional joints with the future potential of leaking.
-luke-
<*(((>< is offline   Reply With Quote
Old 01-12-2012, 06:51 AM   #5
Rewards Points: 280
Bend supports appears to be the best way to do a 90. Thanks.
How to repair a concrete floor we just had repaired! timbo59 Flooring 11 01-04-2012 06:15 PM
First Floor Laundry Room Floor Drain install? hammerlane Plumbing 9 10-21-2011 09:12 AM
Dryer duct hole thru band joist & floor joist justplumducky General DIY Discussions 12 10-05-2010 12:31 PM
2nd floor air flow/pressure fgillis HVAC 7 02-24-2009 04:58 AM
Levelling wood floor gomi_otaku Building & Construction 13 11-27-2008 07:45 AM
