Bathtub Won't Dain Or Slow - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-14-2011, 01:35 PM   #1
bathtub won't dain or slow
sometimes the water drains right out othertimes it sits all day or takes a few hours. tried draino,snaking the drain,vinegar&baking soda. also plunger only works sometimes. i'v been dealing with this for 9 monts. HELP
rlhg123 is offline   Reply With Quote
Old 05-14-2011, 03:00 PM   #2
Rewards Points: 1,578
snake the drain; likely full of hair.
Can try a coat hanger wire with a small hook on the business end; might get to it if you don't own a snake.
bob22 is offline   Reply With Quote
Old 05-15-2011, 10:35 AM   #3
already tried a snake,didn't work. tried draino and baking soda and vinegar. tried blowing it clear with a hose still no luck
Old 05-15-2011, 10:38 AM   #4
Rewards Points: 372
When the tub does not drain, do other drains have the same problem?
fireguy is offline   Reply With Quote
Old 05-15-2011, 10:41 AM   #5
no. only the one tub
Old 05-15-2011, 05:20 PM   #6
Unless there is a vent that serves only that drain line you must have a clog; longer snake perhaps?
The Following User Says Thank You to bob22 For This Useful Post:
rlhg123 (05-17-2011)
Old 05-15-2011, 10:47 PM   #7
have you took the screws out of the overflow/trip lever plate and pulled the rod and plunger out? I used to fix many bathtub drains that were never adjusted when they were installed so it didnt take much to stop the flow. other times the spring clip on the trip lever gets weak and when you flip the lever to drain the tub the plunger will fall back down partially and the tub will drain slow. does the drain in the bottom have the screen cover on it. I have also pulled shampoo bottle caps out of tub drains before when the strainer cover was missing and they dropped a cap and it went down the drain.
The Following User Says Thank You to DannyT For This Useful Post:
Thurman (05-16-2011)
Need a cheap fix to slow bathtub drain need help Plumbing 11 04-26-2016 09:11 AM
slow draining bathtub oh'mike Plumbing 4 02-19-2011 11:09 PM
slow bathtub drain with yucky scum in tub redphoenix Plumbing 7 02-19-2011 10:29 AM
slow flow in bathtub farmerde Plumbing 2 01-08-2009 08:59 AM
Preparing to install Kerdi on bathtub surround DIY-Renovator Flooring 18 07-17-2008 10:42 AM
