Bathtub Without Access Panels - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-26-2009, 05:06 PM   #1
bathtub without access panels
Hello,
I am ready to start my bathroom renovations, and am just inquiring on how to disconnect the drain and the overflow without having an access panel?
thanks in advance.
Joe
sushi_joe is offline   Reply With Quote
Old 05-26-2009, 07:56 PM   #2
Registered User
Termite's Avatar
It is best to access it from below. A 12" hole in the ceiling of the room below is what it'll take in many/most circumstances.
Old 05-26-2009, 11:31 PM   #3
Oldie but Newbie
Originally Posted by sushi_joe View Post
Hello,
thanks in advance.
Joe
You'll either have to go through the wall in the adjoining room or get at it from below via the crawl space or the downstairs room.
LookoutRanch is offline   Reply With Quote
Old 05-27-2009, 08:55 AM   #4
The water pipes and drain pipes are on the outside wall which is insulated, it is directly above my kitchen on main floor, and below my attic.
Will there be shutoff valves in my crawl space? or attic perhaps?
is there any other way without tearing apart a wall in a adjoining room?
Thanks again.
Old 05-27-2009, 10:11 AM   #5
For some reason (probably cost) few tubs have shut-off valves installed. Access is always from an adjoining room or the ceiling/floor below. If needing to access through and adjoining room, buying an access panel, and installing it for future use, is always a good idea.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 05-27-2009, 10:55 AM   #6
Of course you can always cut up the tub and then disconnect but you would still need to demo to make the new connections. Unfortunately there is generally no way to get around it.
hayewe farm is offline   Reply With Quote
Tags
access panel , bathtub , disconnect , drain , overflow
Finishing off access door panel TanMan Building & Construction 12 02-05-2009 06:59 PM
Preparing to install Kerdi on bathtub surround DIY-Renovator Flooring 18 07-17-2008 11:42 AM
Help with ID'ing bathtub sound... DIY-Gal Plumbing 12 02-10-2007 06:45 AM
access panels for plumbing Michaela521 Plumbing 3 04-10-2006 05:26 PM
