-   -   Bathtub Waste Exit Relocation (http://www.diychatroom.com/f7/bathtub-waste-exit-relocation-103065/)
nixplix 04-28-2011 09:54 PM
1 Attachment(s)
Working on a house in NY built in 1948. Sencond floor bathtub was replaced with a newer. The old bathtub waste exit was at point A. Builders cut into upper portion of joist to accomodate pipe to exit point. New tub bed sits lower. Necessary to connect waste exit at point B of "venting system". The "venting system" depicted does, in fact, cut into the top of the first floor.
1. Is it ok to replace the entire length of bathtub vent pipe (the first vertical pipe in image) ?
2. If "1." is yes, is it ok to replace with PVC ?
3. Replace only the section near area B of the bathtub vent pipe by cutting a section in that area and using some type of coupling system to tie into the metal portion above ?
4. If "3." is yes, then what type of coupling system do you recommend.
5. It the bathtub vent pipe even necessary ? I.e. is it ok just to tie into section B, ommitting the entire pipe section above?
6. Would you provide any other recommendation/suggestions
Thank you.
Mike Swearingen 04-29-2011 07:45 AM
I'm not a pro plumber, but until one answers you, here are my suggestions to begin with....
A. Contact your local Building Inspection Department for local code guidance for drain/waste/vent systems and plumbing inspection and permitting requirements. If you ever sell this property, you want to have those permits (and inspection approvals) on file.
B. If local code permits it, you should be able to use PVC to replace parts of the metal d/w/v system.
C. A "mission" coupling would be best and probably required. This coupling has a stainless steel sleeve over a neoprene rubber sleeve with ss clamps to connect plastic d/w/v to metal d/w/v.
D. All fixtures and drains require vents of a speciifed size within a limited distance. I dont think that you can eliminate it.
Good Luck!
Mike
