Old 06-22-2007, 12:20 PM   #1
Bathtub tub spout Diverter broken?
My daughter manager to break the diverter on the tub spout. First How do I get this thing off to look at it. Second is this usually repairable or just replace?
tripower is offline   Reply With Quote
Old 06-22-2007, 12:48 PM   #2
Long-Time DIYer
Mike Swearingen's Avatar
Replace it. The tub spout will either screw onto a male fitting or slide on and be held onto the pipe from the wall with an Allen set screw (look for a slot on the bottom of the spout and the set screw will be up in it).
If it is screwed on, just unscrew it counter-clockwise, get a new tub spout with diverter with the same depth of female threads on the spout or get an adjustable one.
Use 2-3 flat wraps of teflon tape wrapped clockwise only on the male threads of the fitting from the wall if it's a screw-on type. Use a buffer cloth (washcloth works great) on the new spout under a pipe wrench or channel locks. I usually just turn it on and tighten them by hand without a wrench. Works fine.
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
Old 06-22-2007, 02:29 PM   #3
Good Luck!
Mike
Thanks, It is an old school early 60's spout I don't see any external screws on the diverter. I don't feel any resistance on the diverter can I just unscrew the spout or somehow disengage the diverter before removing the spout?
Old 06-23-2007, 12:46 PM   #4
As Mike said, if it is the slip on type, there will be a slot under the spout near where the spout meets the wall. Otherwise, you just unscrew the spout. The diverter is part of the spout and all will come out at the same time.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 06-23-2007, 06:39 PM   #5
Alerady, got it. Very easy, thanks.
Old 06-24-2007, 07:44 PM   #6
Long-Time DIYer
Great! Good job!
Isn't DIY fun?
I've been doing it for more than 50 years (I'm 64), and I've been trying to help people (from an amateur standpoint) for all the years that I've been on the Internet and now have over 14,000 total posts on various DIY websites as a member or moderator. That's almost as much fun as actually doing some DIY thing myself.
However, I won't begin to tell you how many things I've screwed up learning. LOL
Mike
Teflon tape adequate for spout diverter? darsunt Plumbing 1 06-05-2007 02:50 AM
Tub Spout Gap??!? Please help. Mayzee1 Plumbing 7 05-07-2007 04:32 PM
Help with ID'ing bathtub sound... DIY-Gal Plumbing 12 02-10-2007 06:45 AM
Need help with tub spout sherlock Plumbing 1 10-25-2005 04:19 PM
