-   -   Bathtub tub spout Diverter broken? (http://www.diychatroom.com/f7/bathtub-tub-spout-diverter-broken-9336/)
tripower 06-22-2007 11:20 AM
My daughter manager to break the diverter on the tub spout. First How do I get this thing off to look at it. Second is this usually repairable or just replace?
Mike Swearingen 06-22-2007 11:48 AM
Replace it. The tub spout will either screw onto a male fitting or slide on and be held onto the pipe from the wall with an Allen set screw (look for a slot on the bottom of the spout and the set screw will be up in it).
If it is screwed on, just unscrew it counter-clockwise, get a new tub spout with diverter with the same depth of female threads on the spout or get an adjustable one.
Use 2-3 flat wraps of teflon tape wrapped clockwise only on the male threads of the fitting from the wall if it's a screw-on type. Use a buffer cloth (washcloth works great) on the new spout under a pipe wrench or channel locks. I usually just turn it on and tighten them by hand without a wrench. Works fine.
Good Luck!
Mike
tripower 06-22-2007 01:29 PM
Good Luck!
Mike
Thanks, It is an old school early 60's spout I don't see any external screws on the diverter. I don't feel any resistance on the diverter can I just unscrew the spout or somehow disengage the diverter before removing the spout?
majakdragon 06-23-2007 11:46 AM
As Mike said, if it is the slip on type, there will be a slot under the spout near where the spout meets the wall. Otherwise, you just unscrew the spout. The diverter is part of the spout and all will come out at the same time.
tripower 06-23-2007 05:39 PM
Alerady, got it. Very easy, thanks.
Mike Swearingen 06-24-2007 06:44 PM
Great! Good job!
Isn't DIY fun?
I've been doing it for more than 50 years (I'm 64), and I've been trying to help people (from an amateur standpoint) for all the years that I've been on the Internet and now have over 14,000 total posts on various DIY websites as a member or moderator. That's almost as much fun as actually doing some DIY thing myself.
However, I won't begin to tell you how many things I've screwed up learning. LOL
Mike
