Bathtub Suddenly Clogged - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-05-2011, 03:34 PM   #1
Bathtub suddenly clogged
Our tub was draining fine, not slow at all, but all of a sudden now it won't drain barely at all. It will sit for hours before the water finally goes all the way down. I dumbed some drainex down there but that didn't help at all. Any suggestions? Any idea why it went from draining like normal to completely clogged?
Thanks!
Jordan21 is offline   Reply With Quote
Old 08-05-2011, 04:17 PM   #2
Learning by Doing
Leah Frances's Avatar
Don't put any more chemicals down your drain.
I would start with plunging it. Use a wet washcloth to block the overflow while you do it.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 08-05-2011, 09:59 PM   #3
MikeKy55's Avatar
Rewards Points: 254
And if it comes to calling a plumber, make sure you tell him/her exactly what you have poured in there.
MikeKy55 is offline   Reply With Quote
Old 08-05-2011, 11:16 PM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
How old are your kids?
XXX
Old 08-05-2011, 11:24 PM   #5
Plumber
TheEplumber's Avatar
Rewards Points: 792
If it plugged as quickly as you say it wouldn't hurt to check the stopper linkage(if it has one). They've been known to break, especially if old and used often.
Bathtub/ shower tiling buju Tiling, ceramics, marble 37 08-07-2012 07:03 PM
Bathtub Waste Exit Relocation nixplix Plumbing 1 04-29-2011 07:45 AM
Clogged drain in bathtub dc4669 Plumbing 7 04-23-2011 01:23 AM
Preparing to install Kerdi on bathtub surround DIY-Renovator Flooring 18 07-17-2008 10:42 AM
Help with ID'ing bathtub sound... DIY-Gal Plumbing 12 02-10-2007 05:45 AM
