Bathtub Small Crack - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-06-2009, 07:42 AM   #1
hohadcr's Avatar
Rewards Points: 338
Bathtub small Crack
I put too much pressure on one foot of the heavy duty mop holder and pushed a 25 cents quarter sized circled crack on the bathtub bottom. Right now, the little circle is still somehow attached to the surface.
What can I use to fix the crack? This bathtub is 3-5 years old and I believe it is of the modern material.
thank you all.
hohadcr is offline   Reply With Quote
Old 08-07-2009, 09:28 AM   #2
hohadcr's Avatar
Rewards Points: 338
Well, I found online that there are tub repair kits available. I hope that it is the way to go...
Old 08-07-2009, 09:43 AM   #3
RippySkippy's Avatar
I've not seen the DIY kits...another route you could take:
Call the customer service number for the tub and ask them for names of people in your area that are certified to repair fiberglass units. They "SHOULD" have a list at hand...you're not the first to have damaged dub.
Can it be made to look like new....YES. I dinged our bubble tub into the fiberglass (dropped one of the star shaped roman fill handles....ding, ding, ding) I did as I suggest, the supplier gave me some names and he made it look as good if not better than new. I swear to god I cannot tell where he worked unless I stare at the location for minutes....amazing. All for....get this $50!
If this supplier cannot give you a name...start calling the plumbing suppliers in your area.
when it comes to breakfast, the chicken is dedicated, the pig is committed.
LMASD
RippySkippy is offline   Reply With Quote
foundation crack -- uncovering footing AFTER interior drain tile put in? downers Building & Construction 6 05-18-2009 12:07 PM
Crack in Concrete Slab under the Front Door diy4life Building & Construction 4 04-08-2009 09:11 AM
Preparing to install Kerdi on bathtub surround DIY-Renovator Flooring 18 07-17-2008 10:42 AM
Crack in Concrete/Engineered floor Steph885 Flooring 17 04-16-2008 05:52 PM
Help with ID'ing bathtub sound... DIY-Gal Plumbing 12 02-10-2007 05:45 AM
