Bathtub-Shower Caulk Advice - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-20-2009, 10:35 AM   #1
Question
Bathtub-Shower caulk advice
Our bathtub/shower is two pieces, the bottom half with the tub is one and walls for the top is another. Where those two pieces meet there is always mold building up in the crack between. I don't know if this is getting in the walls behind it but I do see some mold starting to form on the wall near this crack just outside of the shower... it may just be from the wet shower curtain touching it.
It is a good idea to caulk this gap all the way aroung the tub or will the caulk just cause water to gather there and make the caulk moldy?
Thanks,
Steve
stevew402 is offline   Reply With Quote
Old 05-20-2009, 11:10 AM   #2
How big is the gap?
From the post I'd clean and dry it very well (weak bleach solution will help) and caulk it with 100% silicone.
No guarantee the caulk won't accumulate some mold over time but it is easier to clean than a gap and watertight.
VaViaCo is offline   Reply With Quote
Old 05-20-2009, 04:22 PM   #3
Wink
Bathtub
It's not very big, just enough to barely fit a q-tip between it. I'll try what you suggested. Thanks
Old 05-21-2009, 10:19 AM   #4
always fill the tub 3/4 way before silicone
metx is offline   Reply With Quote
Old 05-21-2009, 03:06 PM   #5
There is mold and mildew resistant caulking for tubs. Try some Concorbium or similar to kill the mold first.
Chemist1961 is offline   Reply With Quote
Old 05-21-2009, 03:26 PM   #6
Smile
Bathtub
I'll do that. I looked it up and Home Depot carries it.
"Concrobium Mold CT"
Thanks!
Steve
Honey, I'm going to re-caulk the shower... homebound Remodeling 1 02-10-2009 10:11 AM
need to convert a bathtub into a shower q5485 Plumbing 9 11-30-2008 10:39 PM
Grout before Caulk around bathtub? bsippl Building & Construction 6 08-19-2008 09:57 AM
convert bathtub to shower argos Plumbing 10 02-20-2008 12:53 AM
Bathtub Caulk billinak Remodeling 17 05-27-2007 09:34 AM
