Bathtub Rough In Question: Slip Joint Or Glue - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-15-2010, 10:23 PM   #1
bathtub rough in question: slip joint or glue
This is my first house and first time plumbing work. My question might be silly.
I bought a set of bathtub drain kit from homedepot. It uses 1 1/2" schedule 40 ABS pipes and fittings. Instead of slip joints, it looks like everything needs to be glued together including tail piece to P-trap.
Is it a good idea? Did I buy a wrong drain kit?
BTW, I have craw space under the bathtub. So clearance for access is not a problem.
Thanks for any suggestion!!
_________________
Another question:
Do I need to hook up bathtub drain/overflow before rough in inspection? If yes, I don't know how it's possible to plug the bathtub overflow for water test.
pttcc is offline   Reply With Quote
Old 09-16-2010, 06:42 AM   #2
With everything glued, there is zero room for error. Using a slip joint P trap, at least the is adjustment up/down and sideways.
The Following 2 Users Say Thank You to Just Bill For This Useful Post:
oh'mike (09-16-2010), pttcc (09-16-2010)
Old 09-16-2010, 07:12 AM   #3
DIY staff
Rewards Points: 7,174
I think that you may be talking about the over flow/drain set---Same advice---You will find the kits that use slip lock joints faster and more forgiving.
They will also let you use a 1 1/2 inch slip lock P trap--much easier for the novice and easier to service from the crawl space.---Mike---
pttcc (09-16-2010)
Tags
bathtub
Plaster to drywall joint question. ERIK2173 Remodeling 7 05-16-2009 04:58 PM
Ball and Socket Joint Question lateralan Carpentry 9 04-25-2008 09:12 AM
Question on WRONG glue used on ABS Roddy Piper Plumbing 12 12-29-2007 02:36 PM
Newbie question about crack in PVC joint LinusInPW Plumbing 8 11-16-2007 11:25 PM
joint compound question golfer General DIY Discussions 3 01-09-2006 06:19 AM
