-   -   bathtub rough in question: slip joint or glue (http://www.diychatroom.com/f7/bathtub-rough-question-slip-joint-glue-81537/)
pttcc 09-15-2010 10:23 PM
This is my first house and first time plumbing work. My question might be silly. :jester:
I bought a set of bathtub drain kit from homedepot. It uses 1 1/2" schedule 40 ABS pipes and fittings. Instead of slip joints, it looks like everything needs to be glued together including tail piece to P-trap.
Is it a good idea? Did I buy a wrong drain kit?
BTW, I have craw space under the bathtub. So clearance for access is not a problem.
Thanks for any suggestion!!
_________________
Another question:
Do I need to hook up bathtub drain/overflow before rough in inspection? If yes, I don't know how it's possible to plug the bathtub overflow for water test.
Just Bill 09-16-2010 06:42 AM
With everything glued, there is zero room for error. Using a slip joint P trap, at least the is adjustment up/down and sideways.
oh'mike 09-16-2010 07:12 AM
I think that you may be talking about the over flow/drain set---Same advice---You will find the kits that use slip lock joints faster and more forgiving.
They will also let you use a 1 1/2 inch slip lock P trap--much easier for the novice and easier to service from the crawl space.---Mike---
