Bathtub Plumbing Mystery! - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-11-2013, 08:51 PM   #1
Hello DIYchat! I have come across quite a dilemma with my bathtub. The setup: A one-lever control for hot/cold with an overhead shower and lower shower faucet/spout. The problem: I have been having very low volumes of water coming through both for a solid month. When I remove the valve body, the water supply flows extremely well. When I attach the body and reconnect the supply to the diverter and vertical water pipes, it dribbles out, even if I just let it flow through the spout. Attempts to fix: 1) Replacing the shower water body/valve. I even checked the insides of the original body, which were pristine and had no flakes/buildup. 2) The shower head and spout themselves are also clean and do not have any obstructions. They work perfectly on other showers. 3) I tried to flush the vertical water passage (from the body/assembly and diverter to either the spout or showerhead. -to do this, I took a fitted tube and hooked it up to the direct water supply. I then fitted the other end to the top of the shower head (where water is supposed to come out. The water flushes back down the vertical passage/pipe to the spout in a perfect flow. If I reverse this water flow, it dribbles back out again. My suspicion: Could the diverter be clogged between the valve body and the vertical passage? I figured that this would show signs when I reversed the water flow, but it doesn't make sense to me Thanks in advance, chaps.
caonashi is offline   Reply With Quote
Old 03-11-2013, 09:00 PM   #2
  • The setup: A one-lever control for hot/cold with an overhead shower and lower shower faucet/spout.
  • The problem: I have been having very low volumes of water coming through both for a solid month. When I remove the valve body, the water supply flows extremely well. When I attach the body and reconnect the supply to the diverter and vertical water pipes, it dribbles out, even if I just let it flow through the spout.
  • Attempts to fix:
  1. Replacing the shower water body/valve. I even checked the insides of the original body, which were pristine and had no flakes/buildup.
  2. The shower head and spout themselves are also clean and do not have any obstructions. They work perfectly on other showers.
  3. I tried to flush the vertical water passage (from the body/assembly and diverter to either the spout or showerhead. -to do this, I took a fitted tube and hooked it up to the direct water supply. I then fitted the other end to the top of the shower head (where water is supposed to come out. The water flushes back down the vertical passage/pipe to the spout in a perfect flow. If I reverse this water flow, it dribbles back out again.
  • My suspicion: Could the diverter be clogged between the valve body and the vertical passage? I figured that this would show signs when I reversed the water flow, but it doesn't make sense to me Thanks in advance, chaps.
Here is a picture I drew up of how I tried to fix it.
Old 03-11-2013, 09:01 PM   #3
Rewards Points: 636
has the hot and cold water supplies been checked when you tried flushing without valve in. what brand and model is fixture
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is offline   Reply With Quote
Old 03-11-2013, 09:04 PM   #4
Rewards Points: 636
also was the hot and cold turn back on after new valve assembly replaced old and did you make sure it was put in correctly not up side down
Old 03-11-2013, 09:06 PM   #5
Thanks for the quick reply!
The hot & cold water supplies are perfect without the valve.
The brand is unknown, because we moved into the house not too long ago. I'll try to find one like it, but I don't think it's the fixtures (just my guess).
Old 03-11-2013, 09:15 PM   #6
Rewards Points: 83
take the faucet off and plug the pipe off. if it flows good by a new faucet of clean the old one in lime away of mineral deposit remover.
mech_gui is offline   Reply With Quote
Old 03-11-2013, 09:36 PM   #7
Master Plumber
Javiles's Avatar
Rewards Points: 996
Problem may be within the balance control piston if it has one.??? picture or make and model of faucet, would help.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 03-11-2013, 09:41 PM   #8
Rewards Points: 2,110
Unscrew the shower head and see what happens.
Ghostmaker is online now   Reply With Quote
Old 03-11-2013, 10:11 PM   #9
Unscrewing the shower head and doing what? Just let it flow out?
Here are a set of pictures I took just now:
http://imgur.com/cgPEXqc,M3Pv6UI,NfF9Iok,VwwtWd7
Old 03-12-2013, 07:16 AM   #10
copper
Looks like a Delta. Post a picture of the controle cartridge. Did you mess with the temp setting?
Gerb10 is offline   Reply With Quote
Old 03-12-2013, 08:42 AM   #11
Roofmaster
Rewards Points: 2,210
Some cartridges have a screen inside the cartridge itself. Did you check this?
Old 03-12-2013, 07:47 PM   #12
I did open up the cartridge and check the filter; again, no dice.
I didn't mess with any temp settings that I know of.
Here is a picture of the controller. I'm a bit tired of this whole ordeal and will probably call the specialists over. Maybe one of you guys can logic this one out, but I'm stuck.
Old 03-12-2013, 07:49 PM   #13
I cleaned the original one with limeaway regardless and didn't see much debris coming off nor a change in performance.
Old 03-12-2013, 07:50 PM   #14
I posted the pictures, didn't see anything that I would recognize as a balance control piston, then again I'm not a pro in plumbing.
Old 03-12-2013, 07:51 PM   #15
No, it was right-side up and both hot & cold were turned back on.
Tags
faucet , low pressure , plumbing , shower
Replacing the plumbing in the slab teri7513 Plumbing 7 10-28-2012 09:59 AM
Making new plumbing connect to old Cast Iron plumbing fallvitals Plumbing 12 10-13-2012 05:52 PM
Plumbing help! firsttimeremode Plumbing 45 10-05-2012 10:38 AM
Plumbing mystery janecorlee Plumbing 7 09-07-2012 09:22 PM
bathtub rough in question: slip joint or glue pttcc Plumbing 2 09-16-2010 07:12 AM
