Bathtub Overflow Plate. Is This A Problem? - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-18-2012, 02:46 PM   #1
Rewards Points: 166
Bathtub overflow plate. Is this a problem?
Was looking at one of my bathtub overflow plates. Is the gap shown in the photos a problem.
Bathtub overflow plate. Is this a problem?-000_0084.jpg   Bathtub overflow plate. Is this a problem?-000_0085.jpg   Bathtub overflow plate. Is this a problem?-000_0086.jpg
Minus08 is offline   Reply With Quote
Old 01-18-2012, 02:57 PM   #2
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Loosen the screw and slide it over a little,id be more worried about the rust behind there
plummen is offline   Reply With Quote
Old 01-18-2012, 06:51 PM   #3
Rewards Points: 582
well it looks like its suppose to so water can drain out....may need centred alittle....but no its fine..
Old 01-18-2012, 06:55 PM   #4
Rewards Points: 13,458
The gaskit behind it looks funky but other then that it looks fine.
Old 01-18-2012, 09:57 PM   #5
Rewards Points: 166
Thanks all. I will take it off and further inspect.
Old 01-19-2012, 07:36 AM   #6
Rewards Points: 1,500
The gap is the overflow feature. There should be a gasket behind in good enough condition and positioned correctly to funnel the overflow water into the tube behind through which the stopper chain runs for some tub models. The screw(s) in front should hold all the parts firmly together so that the gasket seals well. (A few milliliters of water may remain caught in the gasket between showers.)
While you have it disassembled, just clean off the dirt and rust around the rim of the hole so it looks better when reassembled. Also, if space permits, carefully (sharp edges and fiberglass can cut fingers) clean around the back side of the rim for a ridge of sediment that might keep the gasket from sealing. It looks centered enough the way it is.
Old 01-19-2012, 01:29 PM   #7
plummen's Avatar
There is a little bit of a gap just above the slot on left side
Old 01-24-2012, 12:31 PM   #8
Rewards Points: 166
I took the cover off to expose the overflow tube.
Isnt the gray gasket(shown by red arrow) suppose to be like equal distance around the hole in the tub.
And shouldn't part of the gasket be on the outside(tub surface) of the hole?
The gasket is still soft its not brittle or anything.
Old 01-24-2012, 02:24 PM   #9
Rewards Points: 1,578
Try looking at these instructions and drawings for a Moen drain install:
http://www.moen.com/shared/docs/inst...ts/ins1680.pdf
may give you some idea of one mfg's idea of how to do this right.
bob22 is offline   Reply With Quote
Old 01-24-2012, 10:31 PM   #10
Rewards Points: 166
Has anyone ever used these. Called the ultimate overflow gasket:
Instructions say: Insert Ultimate Overflow Gasket on the outside of the tub and place the new retaining ring over the gasket.
Old 01-24-2012, 11:02 PM   #11
Plumber
TheEplumber's Avatar
Rewards Points: 564
I have not and probably would not. I've never had problems with the factory one
Old 01-26-2012, 02:58 AM   #12
Rewards Points: 166
I took access panel off in a closet to check the backside of the gasket. Looks to be a good seal.
Also why the hell do people(a plumber???) have to use the tub cavity for a garbage dump??
Bathtub overflow plate. Is this a problem?-100_7887.jpg   Bathtub overflow plate. Is this a problem?-100_7892.jpg   Bathtub overflow plate. Is this a problem?-100_7905.jpg   Bathtub overflow plate. Is this a problem?-100_7913.jpg   Bathtub overflow plate. Is this a problem?-100_7916.jpg
Old 01-26-2012, 09:16 AM   #13
Doing it myself
Alan's Avatar
Rewards Points: 2,086
That looks like the tape off the ends of the drywall to me. Plumber is long gone by the time sheetrockers come around.
Journeyman Plumber
Old 01-26-2012, 10:24 PM   #14
Rewards Points: 2,516
I bet if yu look close you'll find some cigarette butts too. Besides that the gasket looks to be making a good seal.
hammerlane is offline   Reply With Quote
Old 11-26-2012, 01:50 PM   #15
TDP
I ordered from here - thanks for posting to my thread; we may have had the same problem!
http://ultimateoverflow.com
I'll let you know how it works. I contacted them and the guy was super nice. I ordered the gasket as well as a cover.
TDP is offline   Reply With Quote
Rotted sole plate in bathroom firemanter Building & Construction 3 11-11-2008 10:06 PM
OK to drill holes in top plate to run conduit? troll5501 Carpentry 4 05-11-2008 08:33 PM
The case of the hanging base plate KaiserS Building & Construction 4 02-02-2008 06:42 PM
Help with Overflow Drain Kit for Bathtub ... njchan Plumbing 1 01-08-2008 11:32 PM
Bathtub Problem!? lockstock Plumbing 6 05-29-2006 08:17 PM
