Bathtub Moves - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-09-2011, 11:49 AM   #1
Bathtub Moves
Hey everyone I am new to the forum.
So I am remodeling a bathtub the problem is I cannot get it flat. This is the first bathtub install i have done. I can get everything level but when i step inside of the tub which is steel enamel it wiggles just a tiny bit. It has the foam on the bottom so I have not put it in a motar bed.
Through all the trials that I have tried the conclusion is that the subfloor must be off a bit somewhere. So anyone have any suggestions. The only thing I can think of next is to pull the tub and pour self level down or make a motarbed.
Thank You!
mnbull is offline   Reply With Quote
Old 09-09-2011, 01:26 PM   #2
DIY staff
Rewards Points: 7,174
Use some mortar ---the foam itself might be tweaked a bit-- That is tried and true--simple and quick.---Mike--
Old 09-10-2011, 10:37 AM   #3
Thanks that's the plan!
Bathtub Waste Exit Relocation nixplix Plumbing 1 04-29-2011 07:45 AM
Caulking a Bathtub, need advice RealMarkP Plumbing 5 03-12-2011 05:25 PM
Fibreglass Bathtub Leaks Need Help cookerz Plumbing 5 02-02-2010 12:40 PM
Preparing to install Kerdi on bathtub surround DIY-Renovator Flooring 18 07-17-2008 10:42 AM
Help with ID'ing bathtub sound... DIY-Gal Plumbing 12 02-10-2007 05:45 AM
