Bathtub Installation Problem - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-28-2013, 06:12 PM   #1
I am trying to install a new bath tub. ( metal with enamel ) and it just doesn't want to fit in. The opening is maybe an 1/8-1/4" too small.
If I slightly bent the flange to get it in, will it be a problem? I don't think it should but I don't want to crack the enamel. ( but it is made to have nails/screws put through it, the flange that is)
jwilkey is offline   Reply With Quote
Old 01-28-2013, 06:30 PM   #2
Rewards Points: 13,458
DO NOT TRY TO BEND IT!!
It will pop the finish off or crack.
Got a picture?
A few wacks on the bottom plate or the studs should move them back enough to get it in.
Old 01-28-2013, 06:30 PM   #3
look and see if any studs are sticking out past the bottom plate and if any
are bowed. used to have the same problem in new houses with the studs not
being lined up with the bottom plate. better to shave the studs then to try
bending the flange esp if its a steel tub, too easy for the porcelain to just
pop where you dont want it to. if you can slide the tub in from the front you
can cut 1/8 inch deep notches in the studs that are sticking out.
how about some pictures?
Old 01-28-2013, 06:39 PM   #4
Ok, I will just notch the studs a little. Thanks!
3 way light switch installation problem Pharand Electrical 7 05-26-2012 10:12 PM
Found Roof Rot due to installation errors after labor warranty expired OneTripper Roofing/Siding 7 06-24-2009 02:59 PM
Aluminum Soffit and Fascia Installation... MoparAutoworks Building & Construction 1 12-17-2006 07:46 AM
Bathtub Problem!? lockstock Plumbing 6 05-29-2006 08:17 PM
