Bathtub Hot Water - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-13-2008, 02:03 PM   #1
bathtub hot water
hey im new here, anyways, my buddy used my shower, and since he did, the hot water wont turn off no matter how much you turn the knob or whatever its called, anyways, i have a plumber coming in tomorrow, but i want to save money and do it myself before he comes in, anyone know what to do? cause i have no clue, i took it all apart and everything looked good, but even after that, i still have the same problem, the hot water keeps flowing outta the tap
Duncan is offline   Reply With Quote
Old 08-13-2008, 02:12 PM   #2
If it is a single handle, the cartridge needs replaced or perhaps the "O" rings changed. If dual handles, this is normally a bad washer on the end of the stem or the seats have worn so bad that the washer does not seal against it. Friend must have 'cranked" on the handle.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 08-13-2008, 04:17 PM   #3
Licensed Master Plumber
mstplumber's Avatar
Rewards Points: 150
Duncan,
If it is a single handle you will probably be able to find a replacement cartridge at Home Depot or Lowe's. If it is a two handle check out this article to learn how to repair it:
http://www.basicplumbingrepair.com/b...g-tips/page/2/
Hope this helps.
Mstplumber
Check out my goofy video for my new toilet repair book.
mstplumber is offline   Reply With Quote
Old 08-13-2008, 05:36 PM   #4
Send a message via AIM to Marlin
How about either do it yourself or call the plumber... It's pretty rude to tell the guy to come out there then cancel the last minute because you decided to change it yourself.
Marlin is offline   Reply With Quote
Old 08-13-2008, 09:06 PM   #5
Rewards Points: 2,906
I agree with Martin.
And I'm glad Martin brought it up because I expect that's what most people thought but didn't say anything.
Nestor_Kelebay is offline   Reply With Quote
Old 08-14-2008, 08:06 AM   #6
47_47's Avatar
Rewards Points: 50
Whose Martin?
47_47 is offline   Reply With Quote
Old 08-14-2008, 11:40 PM   #7
If you've scheduled a plumber to come in and think you'll just tell him your all set when he shows up, think again.
He scheduled you when he could have scheduled another job.
It absolutely baffles me how people completely overlook the fact that they're asking plumbers how to get over on plumbers online.
Plumbermark is offline   Reply With Quote
Old 08-15-2008, 09:19 AM   #8
Doing it myself
Alan's Avatar
Rewards Points: 2,086
how rude!
Journeyman Plumber
Preparing to install Kerdi on bathtub surround DIY-Renovator Flooring 18 07-17-2008 10:42 AM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 08:36 PM
Low Water Pressure Eagle2 Plumbing 5 05-28-2008 10:29 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 10:31 AM
