Bathtub Faucet Leaks From Screw Hole Under Faucet. - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-12-2011, 08:03 AM   #1
Bathtub faucet leaks from screw hole under faucet.
Bathtub faucet leaks from hole under faucet when we run water, especially the shower.
Debmmill is offline   Reply With Quote
Old 02-12-2011, 08:28 AM   #2
Experienced
Jackofall1's Avatar
Welcome Debmmill, to the best DIY'r site on the web.
Hmmmm....leak in the hole under the faucet, could you shoot a picture of that and post it, it would be helpful.
Mark
Old 02-12-2011, 09:36 PM   #3
Long-Time DIYer
Mike Swearingen's Avatar
Sounds like the "faucet" that you're referring to is the tub spout, probably with the pull-up converter knob at the end to turn on the shower.
There are two types of tub spouts, those that are threaded and screw onto a pipe fitting coming from the wall, or those that slip onto a straight piece of pipe coming out of the wall. You apparently have the latter.
There is an o-ring that seals the spout on the pipe to prevent it from leaking like that. The screw hole is for the set screw that holds the spout in place.
The easiest thing to do is to just replace the old tub spout with the same type. They aren't expensive and they're very easy to install...all you need is an Allen wrench to fit that set screw.
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
Old 02-13-2011, 07:43 AM   #4
I think Mike had it right. The plumber came out, did something with a blow torch, said something was too short, and then replaced something. I'm sorry I didn't get more details on what he did. I just wanted to take a shower!
Bathtub faucet leak... bozonoz Plumbing 4 09-08-2009 09:02 AM
Installed a new Moen Diverter and now have leaks at athe hot and cold screw joints Ogies Plumbing 2 06-28-2009 03:01 PM
Moen Faucet Leaks Again!!! mqcarpenter Plumbing 2 01-04-2009 10:02 PM
Bathtub Spout Leaks Behind Spout (pics) wallix Plumbing 7 10-14-2008 04:41 PM
shower faucet Cartridge leaks Dragontat2k Plumbing 2 05-21-2008 04:16 PM
