Bathtub Faucet Leaking - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-24-2011, 09:17 AM   #1
Bathtub faucet leaking
Hi,
I just moved into a new house recently and noticed that the bathtub faucet was slightly leaking when using the water.
It is actually leaking slowly from the top of the diverter. Strangely, it doesn't leak at all when I use the shower head.
I tried to unmount the faucet, but it didn't work (it was loose when I tried to unscrew it).
I don't have an access trap, so this would mean I would have to break some ceramic tiles to do the repair. I was wondering if this was a necessary repair or if I can just live with it.
Thanks!
majas is offline   Reply With Quote
Old 09-24-2011, 03:56 PM   #2
Thanks!
The deck mounted spout has probably been used by the previous owners to raise or lower themselves into the bath. As for the tub spout, I'm not certain that it'll be easily fixable, but the problem will only worsen with time.
If this were my tub I would definitely install an access panel. With an oscillating tool & proper blade, and a little planning, it'll be a worthwhile addition.
Is there an access panel for the jet motor?
VIPlumber is offline   Reply With Quote
Old 09-24-2011, 05:49 PM   #3
DIY staff
Rewards Points: 7,174
I believe that the spout does not unscrew---it simply lifts off a post.
Look for a set screw in the base.
Old 09-25-2011, 10:04 AM   #4
I think I'll try to install an access panel in the next couple of months. If the problem gets worse, I'll have to do it anyway. What dimensions should the access panel be? Also, do you think it is possible to put an access panel without damaging too much the ceramic tiles?
how to remove plastic pipe on bathtub faucet beverly78 Plumbing 3 08-06-2011 08:06 PM
Bathroom Sink Faucet Leaking sgold33 Plumbing 1 01-17-2011 06:16 PM
Very low pressure on bathtub faucet/ showerhead Mermarisa Plumbing 7 10-10-2009 11:47 PM
Leaky Delta bathtub faucet DOW Plumbing 4 01-04-2009 08:33 AM
Leaking Shower Faucet sprtnfan Plumbing 2 12-20-2008 11:08 AM
