Originally Posted by DannyT
that is a moen chateau valve and trim. make sure you twist the puller
first to break the cartridge loose first or you will only pull the center
stem out leaving the outer housing inside the valve body and they aren't
fun to get out without ruining the valve body. i had to replace numerous
valve bodies that people ruined digging out the outer shell with a
hammer and chisel or screwdriver. did you remove the horseshoe clip
that holds the cartridge in?
"moen chateau" got it thanks for this. I will contact Moen to see what my hardware upgrade options are.
I will def get that took to break the cartridge loose 1st.
and yes I did remove the horseshoe clip, that came out fairly easy.
Does new hardware usually come with new cartridge?
Will the cartridge removal tool be at a local home depot? or do i need to go to a plumber store?
