Old 09-07-2009, 10:06 AM   #1
Bathtub faucet leak...
i have a delta tub/shower delta faucet in my bathtub....it has a clear glass ball handle....turn left for hot and right cold....maybe the other way around. i have developed leaks from the ball/handle and from the spigot, as well.
it is approximate twelve years old and i have no idea what model it is....i've looked and cannot find it anywhere...even tried the delta site...no help.
under the spigot is the ring that you pull down to get the water to come out of the shower part.
the leak is pretty bad sometimes, but if you turn the water off with a sharp sudden type motion, it isn't as bad.
any help or advice on what i can do? i've never dealt with this type of thing before.......i'm used to the normal regular old faucets.
is there any sites i can use to see what should and shouldn't be replaced/removed?
thank you for any advice you can furnish. do appreciate your time.
would it help if i attach a photo of the thing?
bill/new orleans
bozonoz is offline   Reply With Quote
Old 09-07-2009, 12:41 PM   #2
pictures help. although is an old style delta which the parts are very easy to come by.
plumber Jim is offline   Reply With Quote
Old 09-07-2009, 02:31 PM   #3
hopefully, this picture will come thru......kinda shakey at this computer stuff.
Old 09-07-2009, 10:00 PM   #4
turn your water off and remove the cartridge and get a new one. It looks like a 1400 series.
Old 09-08-2009, 09:02 AM   #5
thank you...i'll give that a try. appreciate your time and expertise.
bill
Moen faucet leak doseph Plumbing 4 05-27-2009 01:29 PM
replacing bathtub faucet cflo Plumbing 4 05-05-2009 12:10 AM
Bathtub faucet leak in wall seabreezz Plumbing 3 02-15-2009 12:59 AM
Leaky Delta bathtub faucet DOW Plumbing 4 01-04-2009 09:33 AM
