Bathtub Drain -- Without Overflow Waste Trap - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-20-2009, 07:21 PM   #1
I'll introduce myself fully later, but I have a very quick question that could save me hours of work.
I've already used google to find solutions here on how to remove already set PVC pipes, installing a bathtub on a concrete floor, and tiling. I'm getting into the final stretch of a modest basement bathroom remodel and I've become a bit punchy.
I installed the rough in for the bathtub drain and set it in concrete (of course with a 12x12" box around the drain assembly. Last night I cemented the PVC together and had a perfect drain assembly that fit exactly below my new pop and stop tub drain! Exactly below. As I began to take out the drain from the box, imagine my surprise that the drain/overflow assembly is actually L shaped, not straight down, and my perfectly measured drain is now seven inches away from where it should be.
I DO NOT want to saw everything off again. For one, I have a very short tolerance for error as the drain only sticks out about 4 inches below the surface.
So my question is--are there any bathtub drain assemblies that are only a drain straight down without the waste overflow? SO instead of being shaped like an "L", it would be "I" shaped.
Thanks in advance,
sabinh
Last edited by sabinh; 04-20-2009 at 09:19 PM. Reason: I'm uploading a picture of the drain assembly and the bathtub holes
sabinh is offline   Reply With Quote
Old 04-20-2009, 08:48 PM   #2
An "L" or an "I" does not sound good to me a "J" Is good there has to be a place to trap water to block sewage smell.
smorley is offline   Reply With Quote
Old 04-20-2009, 09:04 PM   #3
Oldie but Newbie
Thanks in advance,
sabinh
Let me see if I understand your situation:
The drain pipe is directly under the tub drain hole, rather than in front of the tub, under the overflow?
As long as there's a trap underneath someplace, you should be able to jury-rig a pipe set-up that directs the overflow to your drain. It's just a reverse of the usual situation, where the drain is directed to the overflow.
But is there enough room for the fittings? Can you reach it to work on it?
Is there a shower drain that would work? They're usually 2-inch, but if you could find a 1.5-inch, it might work if there's room.
Oy vey!
I'd be tempted to break up the slab in that area and reroute the drain pipe to the usual place. If you ever have to work on it in the future, you might be glad you did.
LookoutRanch is offline   Reply With Quote
Old 04-20-2009, 09:15 PM   #4
Man of many hats
wrangler's Avatar
Rewards Points: 354
Hate it or not, just do it right! You're only asking for problems later. Like if you should ever have someone overflow the tub, get a clog, want to sell the house or an inspector catches it? It isn't that hard to correct. You saved alot of money doing the work yourself, but spend the few more
dollars to do it right or pay alot more later to have it re-done.
JMTCW
Brett
Man of many hats
wrangler is offline   Reply With Quote
Old 04-20-2009, 09:21 PM   #5
Thanks, guys. You are of course, right
Thanks all for the info. I've seen the error of my ways and will fix it so the drain is installed directly beneath the overflow and not the tub drain hole.
sabinh
Old 04-20-2009, 10:37 PM   #6
Man of many hats
wrangler's Avatar
Rewards Points: 354
By the way, sorry if I seemed to be sarcastic or dismissive, but often people come on here wanting justification for work already done, be it right or wrong. And while this is a DIY site, it is always in your best interest that advice is given.
Some of us have seen many horror stories, be it electrical, plumbing, structural etc., and offer our opinions and advice based on our own experience.
Brett
Man of many hats
Old 02-15-2010, 11:24 AM   #7
It is called a straight tub shoe
Hi, I am new at this site... I stumbled accross your message when searching for the same part. My tub also does not have an overflow drain. The part you are looking for is called a STRAIGHT TUB SHOE. Normally it is only a threaded fitting x hub (glued joint for abs) you can also get them in different finish types for tubs that have an old style appearance and the drain is exposed. They are commonly used with the old style footed tubs. If your tub does not have an over flow you do not want to use a drain kit for a tub that has one. You still do need to attach the plumbing to a P-trap. I purchase my fittings from Central Arizona Supply. Good luck.
Thanks in advance,
sabinh
Sharonmcelrath is offline   Reply With Quote
Trap and washing machine safety drain pan wildbilly Plumbing 18 03-05-2013 08:08 PM
Bathtub drain - subgrade jdeters79 Plumbing 3 11-21-2008 04:17 PM
Basement drain P-Trap collecting waste? drh Plumbing 2 09-19-2008 03:52 PM
Help with Overflow Drain Kit for Bathtub ... njchan Plumbing 1 01-09-2008 12:32 AM
Bathtub drain and w&O overflow connection Manuel6 Plumbing 5 11-03-2006 12:23 PM
