Old 11-02-2006, 10:52 AM   #1
Bathtub drain and w&O overflow connection
I'm planning on intalling a tub and using a pvc W&O. My question concerns how to connect the The 1.5" pvc pipe stubbing out of the slab with the tail of the W&O. I don't want to solvent weld the two pipes with a coupling just in case it has to be disconnected for some reason. Should I connect them with a rubber coupling (fernco...plumbqwik) or might there be some other solution that I'm missing? There is going to be a built in unit of shelves in the bathroom immediately behind the tubs wet wall, so an access panel could be build to inspect any mechanical joint. I want a joint that is going to be strong and am kind of stuck on what would be the best connection. Thanks in advance for any suggestion.
Manuel6 is offline   Reply With Quote
Old 11-02-2006, 11:23 AM   #2
I blame ProWallGuy
A trap adapter and slip joint connection is what is traditionally used, if your waste and overflow is tubular PVC.
If its Sch 40 PVC, then use a no-hub band clamp to join it to the PVC coming up from the slab. This connection is varmint resistant, and a fernco would not be. The band will also help stabilize the joint if there is slight misalignment.
I would definitely leave an access panel if at all possible. If you use slip joints, then the access panel is required by most model codes.
Double A is offline   Reply With Quote
Old 11-02-2006, 11:49 AM   #3
Thanks for your reply Double A. Would using Fernco's proflex coupling be o.k? It's shielded and is practically identical to no hub couplings...
Old 11-02-2006, 09:29 PM   #4
Journeyman Plumber
Ron The Plumber's Avatar
You can use a fernco
Ron The Plumber is offline   Reply With Quote
Old 11-03-2006, 07:16 AM   #5
Thanks for your reply Ron.
Old 11-03-2006, 12:23 PM   #6
I blame ProWallGuy
Fernco Proflex is a good choice here.
