-   -   Bathtub drain and w&O overflow connection (http://www.diychatroom.com/f7/bathtub-drain-w-o-overflow-connection-4614/)
Manuel6 11-02-2006 10:52 AM
I'm planning on intalling a tub and using a pvc W&O. My question concerns how to connect the The 1.5" pvc pipe stubbing out of the slab with the tail of the W&O. I don't want to solvent weld the two pipes with a coupling just in case it has to be disconnected for some reason. Should I connect them with a rubber coupling (fernco...plumbqwik) or might there be some other solution that I'm missing? There is going to be a built in unit of shelves in the bathroom immediately behind the tubs wet wall, so an access panel could be build to inspect any mechanical joint. I want a joint that is going to be strong and am kind of stuck on what would be the best connection. Thanks in advance for any suggestion.
Double A 11-02-2006 11:23 AM
A trap adapter and slip joint connection is what is traditionally used, if your waste and overflow is tubular PVC.
If its Sch 40 PVC, then use a no-hub band clamp to join it to the PVC coming up from the slab. This connection is varmint resistant, and a fernco would not be. The band will also help stabilize the joint if there is slight misalignment.
I would definitely leave an access panel if at all possible. If you use slip joints, then the access panel is required by most model codes.
Manuel6 11-02-2006 11:49 AM
Shielded Fernco
Thanks for your reply Double A. Would using Fernco's proflex coupling be o.k? It's shielded and is practically identical to no hub couplings...
Ron The Plumber 11-02-2006 09:29 PM
You can use a fernco
Manuel6 11-03-2006 07:16 AM
Thanks for your reply Ron.
Double A 11-03-2006 12:23 PM
Fernco Proflex is a good choice here.
