Bathtub Drain System Durability - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-18-2011, 02:48 PM   #1
Rewards Points: 1,062
Question
bathtub drain system durability
i was wondering what the most durable and least likely to ever break bathtub drain systems are. i like the idea of trip lever because they enable a relatively level bathtub bottom (no little knob that can hurt your toe) but i heard the extra mechanism is likely to eventually break. kind of like this one:
http://www.amazon.com/Moen-90410BN-S...1649048&sr=8-7
any suggestion for a drain system that is really rugged?
also, how much difference does brass vs. plastic make? is it worth paying an extra $50-60 for brass?
thanks
Old 11-18-2011, 04:43 PM   #2
JOATMON
ddawg16's Avatar
Rewards Points: 2,124
Most reliable?
Rubber stopper.
ddawg16 is online now   Reply With Quote
Old 11-18-2011, 04:45 PM   #3
Originally Posted by ddawg16 View Post
Rubber stopper.
LOL. thanks but a step more high tech would be nice... maybe lift-n-turn
Old 11-18-2011, 05:32 PM   #4
DIY staff
Rewards Points: 7,174
The one you show uses a piston to block the drain----they are very reliable and can be fixed easily enough if something does go wrong--the only thing to break would be the pop up handle.
amakarevic (11-18-2011)
Old 11-18-2011, 05:34 PM   #5
how about brass vs. plastic? does it make sense spending extra $ on brass?
thanks
Old 11-18-2011, 06:01 PM   #6
DIY staff
The plastic ones will last as long as the tub---but I have never seen a lever action plastic drain--and I hate the lift up or toe pop drains---they get gobbed up with hair and are difficult to remove for cleaning---
So I always use the expensive brass ones.
Tags
bathtub drain
Need a cheap fix to slow bathtub drain need help Plumbing 11 04-26-2016 09:11 AM
Bathtub drain not coming out nhaxton Plumbing 2 11-14-2011 11:11 PM
Bathtub Drain Stopper BrianinBrooking Plumbing 3 11-10-2010 11:13 PM
Permit For Fire Sprinklers letnes Plumbing 18 10-14-2010 05:23 PM
Bathtub drain location kendallk Plumbing 3 11-11-2007 11:02 AM
