Old 11-11-2008, 09:07 PM   #1
Bathtub drain - subgrade
So I'm wondering if I've got myself into a pickle... We're finishing off our basement and decided to add a full bath. Apparently not thinking () I believe I might have ran the bathtub drain line in a not so ideal direction. The picture below shows that drain line below grade as the green box. I'm curious if I'm going to be able to get the drain/overflow/trap plumbed in that area? Looking at our drain upstairs, the drain line runs from the drain end of the tub towards the other end of the tub, completely opposite than what I did in our basement.
Anyone have any experience plumbing a bath that looks like this? Thanks!
Upstairs drain (for reference).
jdeters79 is offline   Reply With Quote
Old 11-12-2008, 08:42 AM   #2
anyone?
Old 11-20-2008, 08:54 PM   #3
Is your drain on the opposite side of the pic of the bath? and is the drain line in the dirt the line you want to tie into?
zosoplumber is offline   Reply With Quote
Old 11-21-2008, 04:17 PM   #4
Where's your overflow pipe for the tub? Isn't there usually a vertical pipe going up to the overflow (and sometimes a cleanout cap above that)?
The way you have it now, it may be very difficult to get a snake into the pipe when it gets clogged, since you will have to go in through the drain. I would put in an overflow, and extend the pipe higher than the overflow (so it's at least a foot higher than the tub itself, not sure what the code is on this though), then cap it with a screw-on cap. You will also need to provide access to that pipe from the wall somewhere.
A closet on the other side of the wall would do nicely.
KE2KB is offline   Reply With Quote
Bathtub Drain - HELP! Terike Plumbing 4 10-05-2008 12:50 PM
Help with Overflow Drain Kit for Bathtub ... njchan Plumbing 1 01-09-2008 12:32 AM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 04:37 PM
Bathtub drain location kendallk Plumbing 3 11-11-2007 12:02 PM
Tile Grout in Bathtub drain naitek Plumbing 1 09-01-2006 08:33 AM
