Bathtub Drain Stopper Leaking, No Access Panel. How Do I Replace? - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-01-2012, 09:35 PM   #1
Post
Bathtub Drain Stopper leaking, no access panel. How do i replace?
Hello,
First time on DIY. thanks in advance.
My bathtub drain stopper is not stopping the water from draining when i have the drain stopper in the closed position. I removed the panel from the tub and pulled up the mechanism and stopper. I can't completely pull the entire set out of the back of the tub. I can only see the top of the "plug". How do I replace that without an access panel to get to the piping?
thanks!
noodle1979 is offline   Reply With Quote
Old 01-01-2012, 09:40 PM   #2
Rewards Points: 12,828
That stopper does just lift out. the shaft is made in two pieces, just wiggle it and the whole thing should slide out.
Often times there something stuck in the drain stopping the stopper from going down all the way.
http://www.mervinzimmerman.com/tubdrain.htm
Old 01-01-2012, 09:41 PM   #3
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Normally you can remove the 2 screws from the overflow assembly in the tub and pull the whole assembly out.sometimes you have to twist it a little as it comes out.
plummen is offline   Reply With Quote
Old 01-01-2012, 10:11 PM   #4
thanks!
I appreciate the help!
Tags
drain plug , shower drain
bathtub access panel amakarevic Plumbing 1 11-18-2011 06:36 PM
Bathtub Drain Stopper BrianinBrooking Plumbing 3 11-11-2010 12:13 AM
Bathtub Drain -- Without Overflow Waste Trap sabinh Plumbing 6 02-15-2010 11:24 AM
Bathtub drain replacement ex-Khobar Andy Plumbing 1 07-15-2009 05:17 AM
Bathtub drain - subgrade jdeters79 Plumbing 3 11-21-2008 04:17 PM
