Bathtub Drain Questions??? - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-07-2011, 09:23 PM   #1
Bathtub drain questions???
I'm a newbie in the process of replacing a tub in my 1953 house and i have a few questions, i searched for awile but couldn't come up with the answers. Maybe these are obvious to most but i'm stumped here...
1) I bought a brass drain kit, how do i connect it to the drain pipe under the house? (old lead pipe maybe??)
2) The drain pipe under the house does a U and there is a "canister" shaped object connected to the pipe that looks like its in bad condition. What is it and does it need to be replaced or axed or what?
3) There is standing water in the drain pipe (under the house) maybe four inches from the top of the pipe. Is that ok or does that mean there's probably a clog?
Thanks so much, i would greatly appreciate any advice that i can get right now, im stuck and the wife want's some progress soon.
tomknox is offline   Reply With Quote
Old 06-07-2011, 09:44 PM   #2
DIY staff
Rewards Points: 7,174
You are new to this,so I'll give you a pointer or two---That 'canister ' is a barrel trap---
They are trouble--plan on getting rid of that and using a 'P' trap---
Post a picture of what you have--there are several licensed plumbers here and a lot of home owners that have done exactly what you are facing.---Mike---
Old 06-08-2011, 12:07 AM   #3
ok so the barrel trap needs to go then first step. then do a p-trap there of pvc instead? what about connecting the drain to pvc, what do i use there? any tips on removing the barrel? i will upload pics tomorrow, my battery just conveniently died when i tried to take the pics! if it aint one thing its another!!
Old 06-08-2011, 06:34 AM   #4
DIY staff
Those barrel traps are connected in various ways---an idea if how it hooks into the drains is needed.
Old 06-08-2011, 08:11 AM   #5
Plumber
TheEplumber's Avatar
Rewards Points: 676
Here is a before and after of a drum trap I replaced. Hope it helps
I Removed all lead piping. Installed new ABS waste and overflow and P trap
Old 06-08-2011, 10:55 AM   #6
Old 06-08-2011, 10:57 AM   #7
ok so this is it here, note that i have duct work all in the way just to make the job a lil more difficult!! does this barrel tie into the main drain i guess??
thanks guys!
Old 06-08-2011, 12:49 PM   #8
Can i hack that sucker off a few inches before the barrel and redo in pvc from there, to the over flow drain connection?
Old 06-08-2011, 03:02 PM   #9
anyone?
Old 06-08-2011, 03:08 PM   #10
DIY staff
Yes---Open the floor a bit more cut the 1 1/2" steel pipe back as far as you can---clear that duct if possible.----That way if you wish to replace more drains in the future the connection is able to be reached from below.
Boot on with a rubber Fernco type fitting and then switch to PVC.
Nice pictures---Mike---
Old 06-08-2011, 03:35 PM   #11
Thanks mike!! Ok, the pipe leading to the left i assume meets to the main sewer pipe, try and take out as much as possible then Fernco fitting to pvc the rest of the way to the tub? As for the p-trap, should i buy a kit or what because im not sure what the angles should be so the trap actually functions right? Thanks again!!
Old 06-08-2011, 03:41 PM   #12
DIY staff
I usually get a PVC trap with a union nut---this allows some fine tuning of the position without glue.
I'll see if I can Google a picture---Mike---
Old 06-08-2011, 03:43 PM   #13
DIY staff
Google Image Result for http://images.bizrate.com/resize?sq=400&uid=2371546897
Old 06-08-2011, 04:39 PM   #14
Hey mike after closer inspection the drain seems to run back to the toilet, would that be correct if they tied it in with the toilet drain?
Old 06-08-2011, 10:08 PM   #15
Yes that's right.I'd be leery of putting a union trap connection like that if it's your second floor in between joist?
Jasonlongor1 is offline   Reply With Quote
slow bathtub drain with yucky scum in tub redphoenix Plumbing 7 02-19-2011 10:29 AM
Bathtub Drain cre10 Plumbing 4 10-20-2010 02:04 AM
Bathtub drain in a new basement bathroom flynryn Plumbing 1 05-28-2010 05:00 PM
Bathtub drain - subgrade jdeters79 Plumbing 3 11-21-2008 03:17 PM
Help with Overflow Drain Kit for Bathtub ... njchan Plumbing 1 01-08-2008 11:32 PM
