bathtub drain plug
A picture would be nice, But if i understand it the overflow has a white or black set of threads sticking out with a thin nut on it. If that is so you need the trim kit for your waste and overflow. You need to know the brand used. maybe a Watco? If its a Watco the the cover just pops over the thin nut. and i am guessing its a toe stop so you just screw the stopped in the strainer.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. , To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. , To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. , To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
