Bathtub Drain Pipe Leaking! - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-16-2011, 05:10 PM   #1
bathtub drain pipe leaking!
Hello, my bathtub drain pipe is leaking(where the copper pipe connects the PVC pipe). I am wondering if some one knows how to fix that. It is almost in the slab and very difficult to reach.
The picture is at: https://lh6.googleusercontent.com/_P...0/CIMG0496.JPG
starwave is offline   Reply With Quote
Old 02-16-2011, 07:13 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 336
Ayuh,... It looks like the metal pipes are Rotten,...
Rip it all out, 'n replace it with PVC tubing, 'n fittings...
Old 02-16-2011, 07:13 PM   #3
DIY staff
Rewards Points: 7,174
I saw the picture---where exactly is the leak? Is it leaking where the brass drain set meets the whiite PVC?
Is the white pipe leaking below that at the slab?
Old 02-16-2011, 08:13 PM   #4
What is under those towels?
broox is offline   Reply With Quote
Old 02-17-2011, 10:08 AM   #5
Actually it is between the brass "ring" and the brass pipe. Hope the pic will work. It is where the arrow points at.
https://lh6.googleusercontent.com/_P.../CIMG0496s.JPG
the white pipe seems not leak.
Old 02-17-2011, 10:10 AM   #6
It is slab...
Old 02-17-2011, 10:12 AM   #7
Yeah, that's my plan. But I don't know how to disconnect the brass pipe and the white pipe... I tried to use the wrench to turn the brass "ring", but it didn't work...
Old 02-17-2011, 10:33 AM   #8
DIY staff
You can break that old nut loose---you need a pipe wrench and a big pair of channel locks---might be a squirt of wd-40 also---
I suggest you replace the old drain set completely---By the time you get the thing apart enough to replace the bad washers---you might as well put in a new drain set.
The only tool you need that you don't own is a drain wrench---it looks like an aluminum dog bone--Cobra Prod. PST170 Tub Drain Remover
That is used to remove/install the chrome ring inside the tub.
Other than that tool--all you need are two pairs of channel locks a saw to cut the tubing and the usual screwdrivers and such.
You will need a small tub of plumbers putty,also.
Old 02-21-2011, 10:53 AM   #9
I got the plier, the drain wrench and WD40. They did work!!!
After I took all those parts off, I realized why there was leaking. The PVC pipe in the ground is so short and it barely touches the Tee fitting.
Is there some kind of coupling I can use to connect the brass Tee fitting and the PVC pipe?
or is there longer Tee fitting I can use?
Thanks!
I clog my bathtub drain with hair-solution works for me gailquilter2 Plumbing 6 07-02-2012 09:20 PM
Removing kitchen drain pipe from wall diyrocks Plumbing 8 02-28-2011 02:37 PM
I clog my bathtub drain with hair-solution works for me gailquilter2 Plumbing 7 08-22-2010 11:11 PM
Major drain issue... what is this pipe? moneymgmt Plumbing 9 08-04-2009 11:53 PM
washer drain pipe paydelady Plumbing 3 11-13-2007 01:27 AM
