Bathtub Drain Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-27-2006, 11:05 AM   #1
Bathtub drain pipe
I plan on converting an existing shower to a bathtub/shower. Generally speaking, how far away from the wall is the tail piece of the waste and overflow? I plan on using a tub box to create a void in the slab; nevertheless, I want to make sure that my stub in the tub box will be in the neighborhood so that I won't have to make too many adjustments late on. Thanks in advance.
Manuel6 is offline   Reply With Quote
Old 10-27-2006, 06:21 PM   #2
Journeyman Plumber
Ron The Plumber's Avatar
The rough should be near 14 1/2" to 15 1/2" from rough wall and 1/4" to 1/2" at edge of valve wall depending on the tub you get
Ron The Plumber is offline   Reply With Quote
Connecting PVC to Galv Pipe fitting for Drain froddan Plumbing 19 02-28-2010 03:33 PM
4 inch drain pipe econdave Building & Construction 7 06-04-2009 11:57 AM
reducing pipe size for sink drain bluebee1314 Plumbing 5 12-02-2007 12:53 PM
HELP! Cement in PVC drain pipe KAT Plumbing 7 05-18-2006 07:17 PM
Leak at flange and drain pipe tallycat77 Plumbing 1 07-26-2005 08:32 PM
