Bathtub Drain Partially Closed??? - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-14-2006, 12:31 AM   #1
Automotive Enthusiast
Sellncars's Avatar
Send a message via AIM to Sellncars Send a message via Yahoo to Sellncars
Bathtub Drain partially closed???
Hello everyone,
I'm new to this forum and sure am gonna use this site alot. I have a koeler bathtub with a American standard faucet system that is very slow draining. I went to clean the drain and it was clean, but i did notice that the handle for the waste and overflow does NOT move, it is stuck down, so i think it is shut partially closed. How do i go about taking this apart? Is there a site with a picture?
I know that i take out the 2 screws and pull out and up, but do i try to take this unit all the way out? Then clean it of any debris?
Thank you,
Sellncars
Sellncars is offline   Reply With Quote
Old 08-14-2006, 08:03 AM   #2
Journeyman Plumber
Ron The Plumber's Avatar
Yes you need to remove the assembly, if if feels stuck, a few swift tugs should free it.
Ron The Plumber is offline   Reply With Quote
Old 08-14-2006, 11:36 AM   #3
If you remove the overflow plate then spray some WD40 down to loose up the stopper. Or pour some vinegar down and let it sit for a while.
redline is offline   Reply With Quote
Old 08-14-2006, 12:43 PM   #4
Sellncars's Avatar
That was the problem guys. I took off the 2 screws and just gave the waste and overflow a quick tug and it came right out. I cleaned it all up and put it back in, it works great. I may take it back out and put some vasaline on it.
Thanks guys,
Sellncars
"Trap" or canister along bathtub drain plumbing Hushpuppy Plumbing 6 06-30-2011 08:26 AM
Bathtub drain and w&O overflow connection Manuel6 Plumbing 5 11-03-2006 11:23 AM
Bathtub drain pipe Manuel6 Plumbing 1 10-27-2006 06:21 PM
Tile Grout in Bathtub drain naitek Plumbing 1 09-01-2006 07:33 AM
Need to move a tub drain to line up with a new tub, is it ok to do this... *PICS* J187 Plumbing 6 05-22-2006 11:13 PM
