-   -   Bathtub Drain partially closed??? (http://www.diychatroom.com/f7/bathtub-drain-partially-closed-3474/)
Sellncars 08-14-2006 12:31 AM
Hello everyone,
I'm new to this forum and sure am gonna use this site alot. I have a koeler bathtub with a American standard faucet system that is very slow draining. I went to clean the drain and it was clean, but i did notice that the handle for the waste and overflow does NOT move, it is stuck down, so i think it is shut partially closed. How do i go about taking this apart? Is there a site with a picture?
I know that i take out the 2 screws and pull out and up, but do i try to take this unit all the way out? Then clean it of any debris?
Thank you,
Sellncars
http://i6.photobucket.com/albums/y22...htubFaucet.jpg
Ron The Plumber 08-14-2006 08:03 AM
Yes you need to remove the assembly, if if feels stuck, a few swift tugs should free it.
redline 08-14-2006 11:36 AM
If you remove the overflow plate then spray some WD40 down to loose up the stopper. Or pour some vinegar down and let it sit for a while.
:thumbup:
Sellncars 08-14-2006 12:43 PM
That was the problem guys. I took off the 2 screws and just gave the waste and overflow a quick tug and it came right out. I cleaned it all up and put it back in, it works great. I may take it back out and put some vasaline on it.
Thanks guys,
Sellncars
