Bathtub Drain Foot Stop - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-26-2011, 09:45 PM   #1
bathtub drain foot stop
how do I remove the foot stop drain if it is missing the x in the middle
william woodall is offline   Reply With Quote
Old 12-26-2011, 09:48 PM   #2
jproffer's Avatar
Rewards Points: 716
Not quite following....maybe a picture...even one online of what kind of stop you have....
jproffer is offline   Reply With Quote
Old 12-26-2011, 09:49 PM   #3
Unhappy
bathtub foot stop drain repair
how do I remove the old foot stop drain if x in the middle is broken off and I cant unscrew it?
Old 12-26-2011, 09:52 PM   #4
Rewards Points: 582
would need a picture but i think i know what you mean ...we cut them with sawzall...being careful not to damage tub...some times using hammer and small chisel taping on edge of strainer works again be careful not to damage tub...
Old 12-26-2011, 10:25 PM   #5
jproffer's Avatar
Rewards Points: 716
This "X" ??
Hmmmmm...."however the HE** you can"...that's the answer
I know that's no help...push it with a sharp chisel, maybe it will dig in enough to turn it.....dont spend a lot of money on this chisel....it will probably be done for when you're done........if it even works.
Old 12-26-2011, 11:50 PM   #6
Plumber
TheEplumber's Avatar
Rewards Points: 834
If you have access below, you can cut through the drain- between the nut and tub with a sawzall. Works pretty good
The Following User Says Thank You to TheEplumber For This Useful Post:
ben's plumbing (12-27-2011)
Foot Lok Stop Tub Drain tate16t Plumbing 0 10-16-2011 12:02 PM
Attaching basement bathtub drain to main drain herbie08 Plumbing 0 04-10-2011 04:13 PM
bathtub drain problem jkinney65 General DIY Discussions 8 01-23-2011 05:26 PM
Bathtub Drain Leaking Que Plumbing 1 10-01-2010 11:57 AM
Can't fix bathtub drain KimberlyS06 Plumbing 3 05-08-2010 11:43 PM
