-   -   bathtub drain in concrete - tail pipe questions (http://www.diychatroom.com/f7/bathtub-drain-concrete-tail-pipe-questions-22352/)
amakarevic 06-16-2008 02:39 PM
i am setting my bathtub in a concrete basement apartment.
got an expensive brass drain assembly by gerber ($75-ish).
Q1: should i use a regular tail adapter between it and the P-trap ? if so, should i use one with or without a tapered washer ? i noticed they have the kind on which the female part is spaced to allow for a washer in between it, the tail pipe, and the male, as well as those with a female part that cannot fit a washer.
Q2: also, does the washer act as a gasket ? this will all be buried, oh by the way
Q3: how do i test that the connection between the tail pipe and the adapter does not leak under a big discharge (tub full of water being released) when the tub has an apron - cannot see the drain ?
Ron The Plumber 06-16-2008 08:52 PM
Why not pipe it with all glue joints?
Alan 06-16-2008 09:57 PM
x2 on ron's post. Take that brass assembly back if it's going to be buried anyhow. Total waste of money. :eek:
As for testing, usually test before sheetrock goes on, so that you can see.
amakarevic 06-17-2008 10:08 AM
it is not the sheetrock that obstructs view, it is the tub ityeslf as it has an apron on it and the other long side is against a wall of the house, not inner drywall.
so go with all PVC drain if it is buried, you're saying ?
amakarevic 06-17-2008 11:39 AM
because the drain is brass.
Alan 06-17-2008 09:42 PM
I don't know what your drains are plumbed with... this is obviously ABS, and I'm sure they make them in PVC also. These are ~12 ish, instead of ~75 ish. They glue completely together, so you won't have adapters that can leak later....
http://www.azpartsmaster.com/Product...BS__3041A.aspx
As far as testing when you're against an exterior wall..... I don't know. We would have told the builder that we were flipping the tub, and put the drain on an interior.
Ron The Plumber 06-17-2008 09:47 PM
You can still use all glue joints below the bass W/O assembly, screw on a female adaptor on the bottom of the brass tee, and take it from there.
Alan 06-17-2008 09:50 PM
I wouldn't even use the brass at 75 bucks if it's buried next to an exterior wall and behind an apron....... those seem like something you'd use on a clawfoot.
