Bathtub Drain Assembly Install When No Access? - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-26-2010, 09:44 PM   #1
Rewards Points: 79
I'm putting in a new tub and there is virtually no access to the underside/back parts of the tub once it's in place (my house is on a slab and there's a furnace right next to the front part of the tub).
How do I install the drain assembly? All the instructions say to put it on the tub, then lower the tub into position, but then I'd be blindly connecting to the drain without any way to secure it with a compression fitting.
Thanks!
thebigsee is offline   Reply With Quote
Old 01-26-2010, 11:43 PM   #2
DIY Junkie!!
Rewards Points: 182
You can buy a tub that has a removable front panel.....thereby gaining access for your installation tasks.
Dugly
YerDugliness is offline   Reply With Quote
Old 01-27-2010, 12:25 AM   #3
Rewards Points: 79
Dugly
I wish I could! I can only use a narrow tub because the alcove is exactly 30" wide stud to stud. I could only find one tub (Performa by Sterling) that fits, and it doesn't have an access panel!
Thanks though.
Old 01-27-2010, 01:54 AM   #4
you are gonna have to build the waste and overflow out of ABS or PVC on the tub then after glue sets pull it off of tub then set trap in the ground for the waste and overflow and last thing you do is set the tub back in and reconnect drain and overflow. A lot easier said than done.
plumbdoc is offline   Reply With Quote
Old 01-27-2010, 01:25 PM   #5
Rewards Points: 79
Can I use compression fittings at all since it will be inaccessible? Or does it all have to be glued?
Old 01-27-2010, 11:02 PM   #6
It should all be glued because it is not accessible. Compression fittings tend to leak eventualy and you will be unable to reach it to replace gasket/ferrule.
bathtub drain leaking Jerry bergen Plumbing 4 04-17-2011 02:06 PM
Shower drain gasket install tricks dbrew Plumbing 6 03-10-2010 09:20 PM
adding new sink / faucet / drain assembly... and I'm clueless :-( diy'er on LI Plumbing 4 11-13-2009 05:36 PM
Removal of Bathtub Drain joe3534 Plumbing 4 10-22-2009 08:41 PM
Bathtub drain and w&O overflow connection Manuel6 Plumbing 5 11-03-2006 11:23 AM
