Bathtub Drain - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-19-2010, 09:27 PM   #1
Bathtub Drain
My basement was roughed in and concreted for a bathtub with no dapout. The problem is the drain is directly below the bathtube drain. The bathtub has about 4 inches clearance underneath the drain pipe. I can't figure out how to plumb it since the drain pipe is directly below the bathtub drain. It isn't leaving me with room for the tub elbow drain and vent tee. Any ideas?
cre10 is offline   Reply With Quote
Old 10-19-2010, 09:59 PM   #2
roto hammer. Chip the concrete back to allow room for the trap
the_man is offline   Reply With Quote
Old 10-19-2010, 10:29 PM   #3
The trap is set inside the concrete. I just don't know how to plumb it since the drain is directly below the bathtub hole since the kits come with an elbow that leads to a tee to the drain usually back behind the tub, not right below it. Any ideas?
Old 10-20-2010, 01:12 AM   #4
That pipe has to come back. Unless the drain was boxed out so you can see the dirt, you'll be chipping concrete to access it. If you have the depth, you can offset the trap arm backwards without cutting out the whole trap. If not the trap needs to be changed. Can you move the wall back to shift the tub?
Old 10-20-2010, 02:04 AM   #5
The wall has to stay bc it is the same wall the vanity and toilet are on.
I clog my bathtub drain with hair-solution works for me gailquilter2 Plumbing 6 07-02-2012 08:20 PM
I clog my bathtub drain with hair-solution works for me gailquilter2 Plumbing 7 08-22-2010 10:11 PM
Removed plunger type drain assembly but bathtub still wont drain. Please help lydiarosestiles Plumbing 3 05-01-2010 11:59 AM
Bathtub Drain -- Without Overflow Waste Trap sabinh Plumbing 6 02-15-2010 10:24 AM
Bathtub Drain - HELP! Terike Plumbing 4 10-05-2008 11:50 AM
