Bathtub Drain? - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-20-2013, 11:41 AM   #1
JOATMON
ddawg16's Avatar
Rewards Points: 1,810
Bathtub Drain?
My wife's new bathtub arrived....need to get a drain valve for it...
Of course I could slap on one of those $25 plastic ones from HD...
Or...the Kohler model for $160....
Any real difference in performance or life?
Old 01-20-2013, 11:48 AM   #2
I use canplas tub kits (the $25 plastic ones). Make sure its an indirect and direct kit. The only time I would go with a more expensive one is if its exposed and the customer will see the drain or wants a nicer drain/overflow trim. Just make sure to use lots of glue on all your joints, to the point where it essentially drips, quarter turn then wipe excess with a rag. Also if its a fiberglass tub, make sure not to get any glue onto it or immediately wipe it off after, as it can stain/eat into the tub/showerbase
BC Plumber is offline   Reply With Quote
Old 01-20-2013, 12:58 PM   #3
DIY staff
Rewards Points: 7,174
If you want a pop up drain---depot does carry Watts in brass for about $65---
Or Watts in plastic for about $35---
For a toe tap/twist and turn---consider a PVC solvent weld unit---about $25---
Old 01-20-2013, 01:35 PM   #4
Plumber
TheEplumber's Avatar
Rewards Points: 662
I like the solvent weld kits.
I believe you're under UPC which doesn't allow concealed compression fittings- they must be accessible- something to consider
The Following 2 Users Say Thank You to TheEplumber For This Useful Post:
Alan (01-20-2013), oh'mike (01-20-2013)
Old 01-20-2013, 02:49 PM   #5
Rewards Points: 4,796
Just on principle, I don't like things with more moving parts than necessary. I like the plain ones.
Which looks like it might trap more hair and soap scum, or break or come apart in a hard to reach place,
this one?
jeffnc is offline   Reply With Quote
Old 01-20-2013, 02:50 PM   #6
Or this one?
Doesn't mean you gotta go cheap, but I'd go with uncomplicated quality.
Old 01-20-2013, 09:41 PM   #7
747
registered
747's Avatar
Rewards Points: 534
Those are the old cylinder ones. They can be a pain to get cylinder adjusted correctly. Over time it can be a bear to get cylinder back out.
WAIT those don't have the cylinder in them. Yes go with this kind.
747 is offline   Reply With Quote
Old 01-20-2013, 10:19 PM   #8
Doing it myself
Alan's Avatar
Rewards Points: 2,086
I actually do like the kohler ones very much, except for as stated by Eplumber, not legal to be installed in a concealed location : IE 2nd floor.
The mechanism is quite simple to install and remove, unlike some of the older styles that price pfister had out.
If you want something without an internal mechanism, look for a PP (push-pull) style setup with a solvent weld drain assembly.
Journeyman Plumber
Old 01-20-2013, 10:33 PM   #9
JOATMON
ddawg16's Avatar
This is the kind of imput I'm looking for.
For the record....the drain (2nd floor) will be somewhat accessable....I'm designing the surround on the tub so I can access the drain.
In our existing downstairs (existing bathroom) I have one of those cable activated drains. I like it....if things get clogged up...it's easy to lift up the stopper and clean things out....I'm leaning that direction....seeing how you guys don't think the $$$$ ones are really any better.
Old 01-20-2013, 10:38 PM   #10
Plumber
Rewards Points: 662
IMO you're just paying for the brass and brand name....
The compression style are user friendly when it comes to making adjustments to fit your tub. Also make sure you get one that will fit a deep tub if thats what you have.
The Following User Says Thank You to TheEplumber For This Useful Post:
ddawg16 (01-20-2013)
Old 01-21-2013, 09:36 AM   #11
Doing it myself
Alan's Avatar
I wouldn't go slip joint on 2nd floor if you can avoid it. I repaired one ONCE through a hole behind the tub, and it worked out ok, but it was a real $@^$@ to get to the nut at the p-trap (below the subfloor) so that I could get it out of the way and cut off the adapter. Not cool.
Journeyman Plumber
Bathtub Drain myowneq Plumbing 7 04-06-2012 09:31 PM
Bathtub drain questions??? tomknox Plumbing 62 08-17-2011 12:09 AM
How to handle bathtub drain when leveling floor Homerepairguy Plumbing 9 12-11-2010 04:47 AM
Slow and clogged shower drain help COBRA90GT Plumbing 9 12-22-2009 02:25 AM
Removal of Bathtub Drain joe3534 Plumbing 4 10-22-2009 08:41 PM
