Bathtub Diverter Spout - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-18-2009, 11:53 PM   #1
bathtub diverter spout
My diverter spout needs to be replaced because it only diverts a portion of the water resulting in low shower pressure. My problem is that I have a 1" water line and all the replacement spouts only convert to 3/4". Does anyone know where I can get a diverter spout for a 1" water line?
Thanks, Lori
LCarlisle is offline   Reply With Quote
Old 05-19-2009, 07:14 AM   #2
Rewards Points: 150
I have never seen a diverter spout larger than 1/2" posting a pic might help.
al's sewer is offline   Reply With Quote
Old 05-19-2009, 03:13 PM   #3
I replaced the diverter spout and water stills comes out of tub faucet taking away water pressure from shower what do I do now.
gellsworth is offline   Reply With Quote
Old 05-19-2009, 09:54 PM   #4
I have seen 3/4 connections for tubspout but not 1". If you indeed have a 1" and it protrudes from tile 1" to 2 " than you may use a bell reducer from 1" to 3/4 or from 1" to 1/2" and a nipple to make up the rest. Your spout should have the fitting towards the nose.
Jefftheplumber is offline   Reply With Quote
Old 05-20-2009, 08:05 AM   #5
Rewards Points: 150
Do you have a 3 handle tub valve or is it single lever or 2 handle?
Old 05-21-2009, 09:18 AM   #6
I have a 3 handle
Bathtub Spout Replacement cspirit Plumbing 4 03-18-2011 07:39 PM
Broken spout on bathtub jmilesrcr Plumbing 5 04-18-2009 11:18 AM
Bathtub Spout Leaks Behind Spout (pics) wallix Plumbing 7 10-14-2008 04:41 PM
Tub spout diverter problem Chaosdragon13 Plumbing 2 05-28-2008 01:23 PM
Bathtub tub spout Diverter broken? tripower Plumbing 5 06-24-2007 07:44 PM
