Bathtub Cast Or Metal - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-08-2013, 04:02 PM   #1
bathtub cast or metal
Hi I have a question how do I know if my tub is cast or metal there's a chip in it and I see black under the white enamel does this mean its metal the house is 17 yrs old
porsha is offline   Reply With Quote
Old 03-08-2013, 04:18 PM   #2
Rewards Points: 12,856
Not sure what differants it makes, they both use and epoxy or enamel touch up paint.
Still going to show but you have to protect the metal asap because both will soon rust.
Old 03-08-2013, 04:21 PM   #3
Sorry I'm taking it out so I just want to know what I'm dealing with if its steal or cast
Old 03-08-2013, 04:32 PM   #4
Just trying to figue this out, what differance does it make?
Cast will make a dull thud when taped on, steel will sort of ring.
Youll know when you go to remove it. A cast will weigh a couple hundred pounds more.
It easyer to just bust it up and haul out the pieces.
Old 03-08-2013, 07:26 PM   #5
Rewards Points: 1,700
Knock on it with your hand if it sounds tinney it is a porcelain on steel tub.
Old 03-08-2013, 07:59 PM   #6
Roofmaster
Rewards Points: 2,172
Do you have a picture of it? They make these things called digital cameras.........................
The Following User Says Thank You to jagans For This Useful Post:
gregzoll (03-08-2013)
Old 03-08-2013, 08:53 PM   #7
DIY staff
Rewards Points: 7,174
Stick a magnet to it-----sounds like a steel or cast iron tub
Old 03-08-2013, 09:19 PM   #8
Rewards Points: 6,652
If your home is in what is typically called a "Tract" build, where the same builder built multiple homes, they would have used the cheapest components, so I am going with a off the shelf Steel tub. Unless it was custom built, or over 60 years old, it would not be Cast Iron.
Of course, the tub we have is a heavy duty Steel, not Cast as we thought, due to the next door neighbor has a twin of our house, that the same guy built, that built ours at the same time. They tried busting it with sledges, and all they could do was chip off the enamel. Once they got it out, they realized it was a steel tub that was better than they make these days.
Voltage in the Shower Deacon98 Electrical 32 01-19-2012 05:14 PM
I&W around pipes and valley metal fastening diyroofer Roofing/Siding 0 09-12-2011 06:39 PM
Multi rib metal roof on double wide...static vents wpilotm Roofing/Siding 0 09-10-2011 04:51 PM
Old shingled to Metal? Sorry...looong! ladynga Roofing/Siding 1 08-31-2011 05:27 PM
Paint a metal bathtub?? Please help! Sarah24 Painting 1 03-16-2008 08:21 AM
