Bathtub Access Panel - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-18-2011, 03:49 PM   #1
Rewards Points: 1,062
Question
bathtub access panel
i was wondering what a good or standard size for a bathtub access panel would be. i plan to put it in the room on the other side of the wall against the drain. the tub is a regular 30x60x14.25.
thanks
Old 11-18-2011, 05:36 PM   #2
DIY staff
Rewards Points: 7,174
14x12 or 14x16 works well---They are a handy addition but not really needed
See what size plastic port covers are available and make the hole to fit it---that will save you some work.
amakarevic (11-18-2011)
Tags
bathtub
Subpanel next to Main panel wired the same in 1990 Uncle Wayne Electrical 3 01-20-2011 12:43 AM
Bathtub Drain Assembly Install When No Access? thebigsee Plumbing 5 01-27-2010 11:02 PM
Finishing off access door panel TanMan Building & Construction 12 02-05-2009 05:59 PM
turn main panel into a sub panel? tikicarver Electrical 2 01-24-2008 07:37 AM
